A few mock ups
Hi Thomas,
Certainly, I have a number of different Dashboards (including the Homey mobile app home screen) that each has a similar version of this display panel (a bit of a beast I know, but there’s a Flow for each tile that varies it’s colour depending on specific conditions… generally green good, yellow, amber, to red bad… except for the fridge where I swapped green with blue, made sense to me
Having to recreate this for each and every different Dashboard, only changing one or two tiles between them, is a royal pain in the posterior… equally so if I want to change something but keep the majority same tiles in step between the Dashboards.
My suggestion was going to be to add a number picker to the Device Values tile widget with a selection of 6,12, or 24 tiles… same widget, just the option to make it bigger (and perhaps if anyone else wanted it, add the option for wider column counts 2, 3, 4).
Then I was going to ask if it would be possible to export a widgets config (like the BroadLink remote app does for IR code settings, with a JSON string) that you could import on other Dashboards… so if you make a change to a configuration of a widget on one Dashboard, it’s just a copy and paste of a JSON string to replicate those changes to the corresponding widget on other Dashboards. Making a tedious process a quick copy, paste n save.
Currently, when I devise wakes up because of presence detection, it take a while to load all the different panels… I was hoping fewer panels would make for slightly easier and faster loading too.
Just wondering: how do you maintain an overview with so many tiles on your dashboard? ![]()
I’m not following, what do you mean?
If I understand correctly, the screenshot you posted is one dashboard page. It is completely filled with device value tiles, without any further structure, like headings per group/type/room or similar. I was wondering how you quickly find the information you are looking for on that dashboard.
Homey doesn’t allow changing the widget options screen depending on a choise. So it’s a fixed number of tile options. 6 is already a lot of settings on one screen.
No that’s just a part of the page.
Headings take up way too much unnecessary space. I know what’s where and what it means… and in my weird n awkward brain
it all makes perfect sense. It’s not completely random or without structure either… The bottom 2 rows are email and phone, the next 2 rows are my NAS, the next two rows are my Homey Pro etc etc.
As long as it makes sense to me that’s okay isn’t it. And it’s colour coded for easy spotting of problems, which then need a closer look. But that is another reason I needed that panel on each different Dashboard to be the same, so I can tell at a glance what is what, without having to get up close and personal with the display ha ha
I don’t really think so. They load in parallel and I haven’t seen much difference between having multiple or just one widget.
Okay, fair point… just thought I’d ask.
What about the copy and paste settings for a widget, to make managing those settings across different Dashboards easier to keep them all in step? (The majority of each Dashboard is location specific, but a status panel like this being the same, so I can’t just duplicate the entire Dashboard, and recreating the same exact settings for one status panel like this on multiple Dashboards whenever you need to update something is a royal pain).
That’s what matters most!
My question was not criticism; I was just wondering
And it makes sense to have the same panel with the same setup in different dashboards, so it is recognizable.
Could easily do this for web dashboards.
Can also make a function to sync web dashboards to native dashboards.
I was soooooooooooo hoping this would be the case. It would make life way easier and more convenient for managing multiple Dashboards (and I do have a few ha ha)
My end game goal is to have an Android screen in every room of the house eventually. Each with a main status panel, and Lights and Devices controls relevant to the room. As well as some common Dashboards accessible from the room Dashboards, like calendars To Do lists etc.
And maybe one dashboard to rule them all, one dashboard to find them, one dashboard to bring them all and in the darkness bind them… (can’t help but squeeze a movie/book reference in somewhere
Those new graph options look great! ![]()
A question related to the Device Values widget. Currently it displays the value of a specific capability. What if you want to show a combined value of multiple capabilities of the same type?
For example, I currently show the power usage (W) of various devices on my dashboard. I have several Sonos speakers and present the combined power usage as one value on the Dashboard.
Of course I can make a virtual device in which I create a new capability that holds the combined usage and link that to a tile in the Device Values widget.
However, it would be nice if I could skip the virtual device altogether. For example by creating a virtual/custom tile in the Device Values widget which value is set by a flow. Or maybe offer an option in which you can select the various subdevices for which the (same) capability should be summed in the Device Values settings screen.
What about a Device Values tile that reflects a BLL variable, like Device Capabilities app AVD’s can do… then your Flow updates the variable, and the widget updates from the variable. It might mean less duplication of code that already exists, otherwise this app is gonna end up being a resource monster ![]()
That version preview looks sick
Your new versions never fail to impress! And your presentation is unmatched.
Outstanding my good man, outstanding. Thank you kindly sir ![]()
That would also be an option indeed. There are many roads that lead to Rome
I understand and no problem. There are alternatives. And the new widgets look very nice.
My thought was based on the current widget I use from the DataVista app. In that widget you can either link the widget to a device capability (and have its value displayed) or use a flowcard to set the value of the widget.
I’d rather do a widget type where you have full control over everything via flows. Then device values are still fine for beginner users and the new widget (Flow Tiles) would be for more advanced users like you ![]()
