[APP][Pro] WhatsApp - Simple. Reliable. Private
@Daan_Dagevos might be. You won’t be the first . Heard this multiple times already
New app update (:green_square: LIVE: 1.39.0):
Changelog:
NEW:
1: None
FIXES:
1: FIX: rollback WhatsApp SDK to stable version. Prevent app crashing
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → WhatsApp | Homey
Yes, whatsapp is causing that.
After the update of 1.39.0 i have warning symbol on adding device page.
The old configuration from my whats app i cant repair, no option for repair.
Now i cant add a new device, warning symbol.
On version 1.38.7 was perfect for me hp19
Report from now
c035685b-2b23-49b0-87fe-fca2a4cc5040
Thank you
Same observation as Fatih Ti. Unable to repair the device since update 1.39.0, even after restarting the application (homay 19 also). The report is 6b015c90-1543-4e7e-b73b-0939e875e865
Thanks
New app update (:green_square: LIVE: 1.39.1):
Changelog:
NEW:
1: None
FIXES:
1: FIX: SDK revert needed separate fixes for HP16 and HP19
@Fatih_Ti @NY79 see above
Work again. Thank you
Everything works. Thanks for the update.
Yessss, from last night messages comming in normaly. THX!
For me it’s not working. I can’t repair it or I can’t add a new device. It won’t accept the code.
@Valentin_Ciopei yes that can be the case. That was fixed in previous versions but i had to go back to a older SDK to prevent the app crashing.
It’s either crashing or some features not working. Nevertheless can you send me a report?
b5483e04-8605-4046-bbd7-d0cbe908f9fc
@Valentin_Ciopei I will check if I can reproduce but I’m afraid I can’t do much at the moment
I really had to revert to an older version. And I can’t upgrade as that will crash out many homey s again
So for the time being we seem to be stuck
I will check it though, I’ll come back on it
I retried and it worked now.
@Valentin_Ciopei nice ! :smiley:
Is there a way to send out a message to two different WhatsApp number, e.g. comma separated (although I tried that and it didn’t work). I didn’t want to use a group, so was looking for sending it via a Broadcast List or some way of adding multiple numbers on the same message?
@Prince_Kumar yes use 2 flowcards
I’m looking for a workaround to make use of the WA App to have a conversation with Homey via flows. The idea is to make a flow that receives a specific message to start EV charging. The flow will respond with a couple of questions via WA chat to get variables like time to finish, start time, number of kW to charge etc.
I’m stuck in getting response to the 1st question, how to make this a dialogue? And how to interpret variables to start an EV flow making use of these variables?
Ideas welcome!
@Yvo this topic is mainly for support for the app not really for building flows
Not sure if people read this topic to help out with flows
