[APP][Pro] WhatsApp - Simple. Reliable. Private
Hi Martijn, d2d5fd44-8ea8-46be-a006-8242510eed61
Homey crasht niet meer, dus top. WA blijft wel crashen en steeds opnieuw opstarten.
Enig idee ook waarom ik altijd deze meldingen blijf ontvangen:
@Willie27 please edit and translate your post
This is a English topic
Already replied to your report:
But WhatsApp is running a temporarily SDK version as the previous one crashed so yes there are some side effects currently until a new SDK version is ready
90472e7c-9c3d-48e9-aa19-4f61e12eab4e
I have spam messages the sync notifications whatsapp
Every 5 sec
@Kevin_Ponsen the exact same question is answered in the post above yours.
ah sorry i was on my phone and it was really buggy with all the messages so couldnt read the above topics :smiley:
i will turn the app off and will wait for the update / fix
thanks for the quick reply keep up the good work !
This flow triggers a whatsapp to a group:
However, only I receive the message:
My wife, the other member in the group, sees only this:
What am I doing wrong?
@Niels_Kloes nothing. It’s a known issue and not something I can fix now
I had to revert to a older version of the SDK due to memory issues with the newest version this is unfortunately a side effect of not being up to date
I’m still waiting for a SDK update
OK, thank you.
Hello @martijnpoppen . I am trying to add the Whatsapp app to my Homey 2019.
The only thing is, the phone says that after entering the code that something went wrong.
I did restart the phone and also my Homey.
This did not work for now.
The app has worked just fine for months. I did get problems after the last couple of updates.
Maybe you can see something?
2e89eeae-576a-497a-8bfb-9244a75c8fea
Thanks
@Mike1233 yep nothing I can do for now
Had to revert to a older SDK due to memory issues
The older version has side effects
When the SDK is updated I can update the app again.
@martijnpoppen
Ok. Thank you.
But strange because it had worked on my 2019 Homey.
I wil wait.
Somehow my app seems to be stuck, restarting doesn’t resolve it and it’s stuck at “reparing” status. After a while the whole Homey even crashes… Tested now 4x and all 4x the homey crashed..
When doing an actual repair i get: a timeout.. Any ideas? I have many flows with this app, so would be sad if i need to reinstall :frowning:
Please, read the last 10 posts, then you know, You have to be patient.:man_tipping_hand:t2:
Please, read the last 10 posts, then you know, You have to be patient :man_tipping_hand:
New app update (:orange_square: TEST: 1.39.2):
Changelog:
NEW:
1: None
FIXES:
1: FIX: minor SDK fix. Fixes pairing issues
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → WhatsApp | Homey
Well, i waited 30min plus, nothing happened. Removed the app, restarted homey and phone. Since now i cannot even pair the app anymore. It keeps saying failed to add.
Edit: The BETA version does work, but yea, now i only need to rebuild 120 flows…
@NoWorldOrder glad to hear that TEST works
For your flows you can use this: [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
@martijnpoppen Installed the testversion on my HP 19. Now i can add a device.
But i can not send a message. When i send something like a text it says, NOT_A_NUMBER.
I use a number like +31612345678.
Has this also something to do with the SDK?
@Mike1233 please send a diagnostic report
@martijnpoppen Did send a rapport yesterday by the app but did not copy it here.
Made a new one.
5280488f-0ccc-4640-82a7-0dc9b19776a6
One card has a number that says NOT_A_NUMBER and one piece of the flow sends something after 2 seconds buT with a empty card.
