[APP][Pro] WhatsApp - Simple. Reliable. Private
Hey @Deadlifter
You could maybe use something like this JSON Handler App for Homey | Homey
Then you can add the number to a list and later on when a message is received check that again.
I don’t have something like that in the WhatsApp and don’t think it fits within the app.
So I would recommend search for apps on homey which can create a list of data based on a flow card
When i add Group link and do test , i receive error : Not a Number
Someone already found solutio for this ?
@Helmut_Willems please send a diagnostic report
send a replie
@Helmut_Willems make sure to try the group chat again and then send a report
Currently this error does not show in the report
resend after test
@Helmut_Willems I don’t see anything which is causing that error.
Did you paste the full share link in the recipient field?
Like this:
https://chat.whatsapp.com/IjVEkqewlfjweiwhdo
@Helmut_Willems looks like there’s a space before https?
hello
Stupid fault , idd there was a space before
but now i send a test msg , but the msg won’t arrive in the group.
send report
@Helmut_Willems is homey admin of the group?
Hello
I am admin of the group , connect with my account
@Helmut_Willems and your account is the account in homey?
Already tried a restart?
Restart Fixed the problem
Hi Martijn, it already works for me it seems that the group link was changed by whatsapp they removed the - caracter which was in my grouplink variable I had setup earlier.
So the - before HE was removed by Whatsapp this could be the issue with others aswell.
I also made it smarter to put it in one flow instead of putting it in each flow separate, if somethings breaks down you only have to change this flow and nothing else.
After (re)installing the app (the app dissapeared suddenly), I am unable to add a WhatsApp device.
Diagnostics report: ba3d9dd6-5a3c-4c07-b90c-b898fe1cd9ff
@Sander_Muurmans the report is completely empty.
Already tried a homey restart? Looks more like a homey issue
I use your app with full satisfaction for sending camera snapshots at the frontdoor to my households phones.
Lat few months however I run into an issue that the connection between homey and whatsapp randomly loses connection. After restarting the app, the problem is usually solved. This happens now every 1-7 days and I need to restart the app.
Any idea what the cause might be? Could it be the app or Homey itself?
@Joram Please send a diagnostic report when that occurs. Do you also use this whatsapp number on other devices, if not make sure to use it every once in a while. Because whatsapp web will be logged out if you’re not using the native app anymore
Thanks for your reply, I will send the diagnostics report when it happens. I do use the number on my phone for whatsapp as well.
