[APP][Pro] WhatsApp - Simple. Reliable. Private
Let me uninstall and reinstall, the update was 1.29.0 and should work?
@Phil_Bro yes that’s correct!
Just reinstalled the app and tried 2x .. Loading … Will do a Mac DNS flush tomorrow morning as I expect something local..
New app update (:green_square: LIVE: 1.29.3):
Changelog:
NEW:
1: None
FIXES:
1: FIX: for HP19 - nodejs not working with new SDK
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
Hi Martijn. Just reinstalled again and tried. After entering telno. is says loading … then this text disappears and homey reports (in red) driver missing 2x and the sequence restarts. Doing this the second time and loading appears and stays forever.
Do I need to install additionals? Running homey late 2019 updated.
@Phil_Bro which homey are you on? HP19 or HP23?
@Phil_Bro HP19 still has issues i saw, therefore also multiple updates yesterday evening. something changed in the SDK causing incompatibility with HP19 (nodejs 16). So investigating what i can do to fix it. But actually running nodejs 16 is the issue.
OK! Well that satisfies me, to know the cause to find the root cause is a start. Thanks so far. If you want me to check on things, let me know.
It appears that you’re not using https://homey.app/en-nl/app/com.whatsapp/WhatsApp/**test**/
as others do use the /test/ to allow testing prior to put mods live instantly.
@Phil_Bro Normally I use /test (link). But as I made a “hotfix” i thought it’s better to put it live immediately, not knowing there was a critical update for lower node versions
Perfectly understandable. I’ll wait for the version for me, again no sweat as it has no high prio here, for others I don’t know the level of patience :slight_smile:
@Phil_Bro the number of HP23 is a lot higher on this app. So should work for 80% of the users :wink:
As I have 3 HP19 operational and 2 spare.. but most of all a lot of apps did prove not ready for the 23 model, I decided to wait. So I accept the 20% exception for your app :laughing:
New app update (:orange_square: TEST: 1.30.0):
Changelog:
NEW:
1: NEW: NEW: add fallback for older nodeJS version to work with WA SDK
FIXES:
1: None
@Phil_Bro can you give the above test version a go? I’m not at home so can’t test on my hp19.
Edit: Did test on my Hp23 and that still works :slight_smile:
Installing as we speak. Hold on for edit
EDIT : We have a lift-off ! Registration worked. Assume that the app will do what I want, but need to test later this week as meetings will consume me big time.
Let me know when the test mods are in the live version, as I will switch mine accordingly.
Thanks for the efforts Martijn, appreciate this!
@Phil_Bro good to hear!
Will probably change it to live within 3 hours. So if you install the live version this evening you’ll be fine :slight_smile:
New app update (:green_square: LIVE: 1.30.0):
Changelog:
NEW:
FIXES:
1: None
Big thanks to all the developers who made the app work again. The new update fixed the problems.
Regards,
Alex
@Alex_Wijnsma only a single developer here. And ofcourse the devs who made the SDK :slight_smile:
Thnx @martijnpoppen het werkt weer :+1:
