[APP][Pro] WhatsApp - Simple. Reliable. Private
What are you trying to do ? Not sure I follow. Probably using some app, did you check related app thread here on the forum ?
First tell us please which of the several WhatsApp apps for Homey you are referring to.
[APP][Pro] WhatsApp - Simple. Reliable. Private - #1403 by martijnpoppen
It’s down, and not yet resolved
when you want to link this to your whatsapp it indicates that the number is incorrect or that you need to request a new code. Tested with whatsapp and whatsapp buisiness. It also does not work with different phone numbers. Numbers are definitely filled in correctly.
Regards
@Alex_Wijnsma this is a English topic
Please edit your post and translate it
Thanks
Also see the post above yours…
done
@Alex_Wijnsma as already mentioned the answer was in the post above yours
But here you go [APP][Pro] WhatsApp - Simple. Reliable. Private - #1403 by martijnpoppen
we will see the fix asp. Thanks
Same here, wish to use the WA app, Telegram works flawless but I need to send reports daily by WA. Hope to see the fix for adding telno. as there are a lot of people waiting. Thanks!
@Phil_Bro of course but as mentioned I’m currently not available for homey development
Hope you are not restricted by someone and you find time for this as the original app landing page does not mention incapabilities. It took me 2 Hours to find out the app cannot be installed.
Anything we or the people waiting can contribute to get things rolling?
@Phil_Bro no because it stopped working last week. If I had time to update the page I had time to update the app.
I’m not restricted by anyone :wink:
Not much there can be done. Only the SDK needs to be updated inside the app, quite a simple task
And maybe not necessary but a reminder, this is a community app. So the developer (me) works on this on a voluntary basis. So please be patient
Hi Martin, appreciate your concern. I did contribute a lot lately, so I understand. Take it easy!
New app update (:green_square: LIVE: 1.29.0):
Changelog:
NEW:
1: NEW: update Whatsapp SDK
FIXES:
1: FIX: pairing error
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
I’m back again! :palm_tree: :beers:
FYI See update above :slight_smile: @Phil_Bro @Alex_Wijnsma @Patrick_Van_Deursen @John_van_den_Bremer @Jaomrodri @Derivator @William_Damen @MozartSailor @Bentley040514 @ChrisBoer
SUCCESS!!!
thanks @martijnpoppen
Glad you are back, didn’t know you left :slight_smile: Just tried to pair, after telno input, it hangs, stating that its loading.. but what does it load ..
@Phil_Bro Yep, that’s why i was “unavailable for homey development” :wink:
did you install the latest version?
It works!
Thnx
Works here as well :+1: Thanks Martijn!
