@_Bredero please translate your post. This is a English topic
@_Bredero and then please remove the dutch post..
But to answer your question this app does work with Whatsapp Business.
Where do you see the 6 grey boxes? (in the whatsapp app on your phone)?
And acting on incoming calls is not possible with this app
@martijnpoppen i see the 6 grey posts in the WhatsApp app on my phone.
It’s not possible that, when WhatsApp give the message: 1 missed call, that Homey can respons to this message with a standard message that incoming calls not possible?
@_Bredero which phone are you using?
no that’s not possible
Okay.. i use a iPhone. In this case a iPhone SE 2020
Maybe a new feature for the future ![]()
@_Bredero as already said twice… it’s not possible
@_Bredero can you try a newer phone or pair a Bluetooth keyboard to your phone. WhatsApp has issues with the codes on older models. Nothing I can do but meta doesn’t seem to fix it
Okay, thanks. I will try it with a Bluetooth keyboard. Thanks for your help and patience. Have a nice evening.
Hi Martijn,
Both my whatsapp devices have an red exclamation mark.
I tried to repair but it gives an endless loading sign.
Tried to reinstall whatsapp without deleting it. Tried to restart homey and the app. Any other ideas?
Edit: at the end, i get this code: Not Found: PairSession with ID 69ef335a-f74a-4d08-a0c8-038548818fdb
and the app crashes.
HI @Glenn_Dijkstra
already tried to remove and re-add the device?
There’s an issue with the repair option and it crashes the app instead of repairing
Thx for the quick response!
I see, I see. Didnt try it yet as i have quite alot of cards and i prefered the repair option ;). Any idea if this issue will be resolved anytime soon? If not, i ll just re-add. Will your repair-script work for whatsapp devices?
@Glenn_Dijkstra I don’t expect a fix soon
Yes repair script works !
I have added my WhatsApp to Homey. When i setup a flow with: send a Whatsapp-message… to mobile number/group, i can only fill in a mobile number or grouplink.
When i click on the label, i see only 2 labels: “Send data yes/no and Delete all widgetmesasges yes/no”.
Must i create a logical flow or something else so i can send a message to the original sender or a group?
Maybe i looking at the wrong place. I hope you can help me.
I want to create something like this: Kantoor flow: out of office whatsapp bericht maken – Homey Cornelisse
Regards,
Adriaan
@_Bredero sorry its not clear to me what you mean
Please attach screenshots so its clear what youre trying to achieve
How can i activate this message for example? a respons to the “afzendernummer”. Can i fill in afzendernummer? this is not a label i can select
@_Bredero ofcourse because you have to create that variable first if you want that.
That’s default homey behaviour. but you can also fill in the number yourself.
Please search the forum for variable usages if you are unware of that.
And the “afzendersnummer” only appears if you draw lines between the cards.
Okay, normally i can select the label, i will create a variable for this usage. Thanks. Have a nice easter
@_Bredero yes attach the cards and it works
@martijnpoppen, thanks. It works.. normally first i create the different cards and fill in all the details, at the end i attach the cards and test it. Before i send this question, i don’t have attached the cards and check of the variable are visible. Thanks for your patience ![]()
