[APP][Pro] WhatsApp - Simple. Reliable. Private
@_Bredero nice
Best practice is to connect the cards immediate
A lot of trigger cards have tags attached to them. You can see it in the card it self it shows a small icon
Hi, i use Homey for many years.. first time i see the small icon…:see_no_evil_monkey: haha thanks for the tip​:wink:
I can’t for the life of me figure out how to get the “senders number” and “sender” cards to work. Here’s a picture of my flow:
I printed out the sender name and number and keyed it in exactly as what I saw in the “senders number” and “sender” cards, but the flow would never get processed, i.e., it can’t match the sender number.
Can someone advise what is wrong?
@Darkness sorry but this is not really a clear image.
Please provide what you’re trying to do. Input and expected output.
What i wanted to do is to simply filter a message by the sender and number so that i can process it. I can confirm that the app receives the message, but somehow it is unable to match the sender or the phone number.
@Darkness please try a simple flow without the extra check for a variable. now you’re combining all things together. Just try step for step and see if that works, then start expanding the flow
This is a sample of the test flow that i used. It is unable to detect the phone number. If i delete the And card, it works.
@Darkness and you did add the + icon to the senders number?
Yes, with the country code.
@Darkness i don’t recognise this and can’t reproduce. are there no spaces in the input field?
please send a report after running the flow
There must be some unexplained bug ongoing. I created an advance flow (instead of standard flow) using only the simple cards and it works. I then proceeded to replace all of the previous cards that didn’t work into this debugging flow and replace them with exactly the same cards except that i created them again from scratch and then it works. After that, i copied the entire flow again from the debug flow to the main flow and it stopped working again.
I created the diagnostic report 48f726c8-a1a7-4a2c-84d7-ab91e03ed7e1
@Darkness ok so it works with only WhatsApp cards. Are you sure that the variable check works?
Report looks good
I deleted all the cards from scratch and created them again and it works. So what i did now is to split the flow into 2 separate flows and it now works.
GroupID not found when sending to WhatsApp Group Invite id is opening the correct group when clicking on it.
@ChrisBoer is homey in the group and also admin ?
the whatsapp number added to homey whatsapp is admin in the group
@ChrisBoer please send a diagnostic report after trying to send a message
I got a similar issue as @ChrisBoer, I am unable to send to certain WhatsApp Groups.
Diagnostic Report: c0979804-7da6-455e-ac6f-1ed48eb4f067.
Thank you @martijnpoppen for the great app!
@MozartSailor can you try to restart the app and try again?
Have done so. Still the same.
Diagnostic Report: afe03b1d-a53d-4d48-9906-a61bdd4fca2c
