[APP][Pro] WhatsApp - Simple. Reliable. Private
Understand … have been busy for a week to get the flow working again as it broke down.
No clue what caused it (could be my fault I did some wrong).
It seemed so easy …
Don’t worry my flow works again. There’s just a difference between the AND cards from homey and your app.
I found the difference … I used the sender and sender nummer wrong sorry
@Jeroen_Hus ah! good that you found that. Then for now i won’t make any changes :slight_smile:
I’ve got it working. Restarting the app did the trick. But after a few hours, it fails again. So i made a flow that restarts the app twice a day. Didn’t have any issues since.
New app update (:green_square: LIVE: 1.27.14):
Changelog:
NEW:
1: None
FIXES:
1: FIX: use cloud url or construct own url when Homey ManagerImages doesn’t provide the localurl
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
Hi.
Recently, I can no longer connect my Homey to WhatsApp. After entering the number, it keeps loading. I do receive a notification on WhatsApp, and I accept it, but a connection code never becomes visible.
report sent: d6d44f1f-72e5-4c62-8c3d-4d7718daffcd
Thanks!
@Kees_Hendriksen please translate your post to English this is a English topic
For your issue: use the homey webapp
thnx! that was the solution, i send myself a text message every 12 hours.
a
Hi Martijn, I am working on a flow for an automated (vacation) message. I would like to add the option to exclude the message when I send a message. Is it possible to add a card based on incoming / outgoing messages? Please advise,
@TonySopr so if I understand correctly you want to ignore a specific number ? Currently not possible and don’t really see that as a feature of this app as the native WhatsApp also doesn’t have that option
Hi, since today WhatsApp is not working anymore? Anyone else also has problems?
@Glenn_K did you already try a repair of the WhatsApp device in Homey ?
Thats also not working :frowning:
@Glenn_K you clicked the repair? Did you try via homey webapp?
Repair over phone (web) did not work. Over Chrome on desktop did! Thank you.
Hello Martijn,
thanks for your applications and very happy new year,
Maybe the tip has already been given (i don’t found), I want to know how to insert a CRLF in a flow message. I tried with ‘\n’ and ‘\r’ but it doesn’t work.
Thanks
Hey @YChabi
Thanks and happy new year to you too
You can just add a ENTER in the text field and it will convert to a line break in WhatsApp
Hello Martijn,
I have been using the application for 1 month and everything was perfect.
For 1 week, I haven’t received any messages.
So I uninstalled the app and reinstalled but nothing worked.
Do you have an idea? I created a diagnostic report 35c9a753-5445-459d-acf5-0d5fdd540720
Thanks
@NY79 hi
I don’t see any issue in the log
Can you elaborate a bit on the issue so I might understand it better
I created a flow that sends me a photo taken by a camera in the event of motion detection. But for a few days, I no longer received a message in the event of detection, including when I take a test.
THANKS
