How to share a flow? Anyway… even a simple flow with WhatsApp - Receive Message will not run when receiving a message. Sending is still no problem…
It worked for months now and stopped working out of the blue
@Michael_Fritzsche please send a diagnostic report
I can’t help you without that (How to send a diagnostic report)
Hi, the app keeps crashing after the update to Homey Pro 12.2.0. Please help.
This is the diagnostic report that I sent:
3bf413b8-64aa-4e31-947a-af3d49885eb7
b19fb61b-123a-4419-b1d1-a18204c2d0c6
@MozartSailor not much I can do for you. Try a restart of your homey
Looks like a homey memory issue
@Michael_Fritzsche the flow trigger seems to work perfectly when I check the logs.
Something must be wrong. Even when i send a push notification on WhatsApp receive message, i get nothing. When i test the push, all works fine. My flow which depends on receive message worked fine and now its impossible to get it running again… the receive message my be triggered, but its not forwarding the event to proceed
@Michael_Fritzsche according to the report it is…
So there not much I can do here
Also just tested myself and it still works. But please share your flow.
I still have no clue, how to share a flow. There is no export…
@Michael_Fritzsche a screenshot would work
@Michael_Fritzsche if the first 2 work but the last doesn’t then it’s a configuration issue and not a app issue.
this flow was working for months and broke out of the blue. Now not even the received message is recognized. How can a flow break? I added a push notification on every step, after it stopped working. If i start it manually (test) all works fine… i also replaced the starting event … the whole flow seems not to be fired at all… i created a ticket at atom now.
@Michael_Fritzsche but that’s strange right if the other flows work
Is the flow disabled maybe?
You are right… I found in the logs: Flow deactivated because it was executet to often … what the…
Thank you. I tried restarting Homey, but it was still not working. So I uninstalled the app and reinstalled it. Now it works. It’s going to take a while to relink all my flows, but it’s working!
Thank you for your great work!
@MozartSailor nice!
Btw a repair of the device would probably have helped as well . That keeps your flows
But for fixing your flows there’s a script: [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
Hi Martijn,
just freshly started with your app today.
regretfully the “Een nieuw bericht is ontvangen” trigger does hpwever not work.
I made a group with my business phone as connected device, and created a group to which my private phone is connected.
Sending messages works as expected, no trigger is created however.
Can this be solved? Receiving messages is why i installed the app in the first place as it seems to be the only way you can influence a flow by answering to it.
Thanks in advance!
@Ronald_B with which device do you send the messages to the connected device in homey
Please note that sending a message to your self will not create a notification (just like normal WhatsApp)
Hi @martijnpoppen, i have exactly the same problem as @TMS_TMS is / was having. Send you a error report 9a1486c8-826c-4110-baa8-7d69893c5f3e.
Every thing was working until yesterdag. Sending text no problem, sending picture notting.
