[APP][Pro] WhatsApp - Simple. Reliable. Private
@Stefan_1 this is due to the changed mentions. See [APP][Pro] WhatsApp - Simple. Reliable. Private - #1009 by martijnpoppen
So everything after @ is taken into account as a number. However it shouldn’t fail the flow. Will check that
New app update (:green_square: LIVE: 1.27.9):
Changelog:
NEW:
1: None
FIXES:
1: FIX: don’t throw an error in flow when @ is part of content and not a number
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
@Stefan_1 fixed :point_up:
and thanks a lot for your kind donation!! :beers:
Wow this was the fastest fix ever. Soooo great. works with 1.27.9 :tada:Thanx @martijnpoppen
Hi Martijn,
I can’t seem to figure this out. Hope you can help me.
I created an insights graph that I want to share with a whatsapp group. I’m admin of the group; the link is correct - no spaces whatsoever.
If I send a text message to the group; it’s working. But if I use the card including an image and I add that tag of the graph that is created in the flow I am not receiving the message at all. I’ve tried this also with different types of images (from my Eufy cams for instance) and with phone numbers. In all cases I’m not receiving the message.
Could you help me out?
@marquetphilippe please run your flow and send a diagnostic report so i can debug the issue
Question: Today i missed some whatsapp messages that should be automaticly send every Tuesday to me. This afternoon when i was checking the status in Homey I saw that i neede to config it again.
When checking on google what I can do or what this can be I read that after 30 days inactivity on the paired connection.
Is this something that should or is going to be updated, when Homey is sending me messages?
Or
Do i need to do something once a month to get the connection up and running?
I don’t know now if there is something changed or I have done something wrong, that is was disconnected. But I don’t receive a message when it is done, so that makes it difficult for me and I miss important messages.
I hope that someone can assist me with a solution :slight_smile:
@smv yes WhatsApp expect you to use the app on the phone often. Only using web WhatsApp will disconnect after 30 days
In this case the homey WhatsApp is a WhatsApp web instance
So if I understand it right, i need to open sometimes on my phone Whatsapp Business, to make sure it not disconnect?
@smv yes!
@marquetphilippe checked your report but looks like the image you’re trying to send doesn’t have a url. So WhatsApp can download it first to send it.
Really strange. Can you try a homey reboot, run the flow again and send a new report if it doesn’t work
New app update (:green_square: LIVE: 1.27.10):
Changelog:
NEW:
1: None
FIXES:
1: FIX: properly add transparent mode to widget
Hi Martijn, need your help / advice. I had to move to a new iPhone and WhatsApp App on Homey said it does not work anymore so deleted the App and reinstalled and did register homey in WhatsApp again but then it hangs in the add device screen forever and does not add WhatsApp to Homey.
I sent a report : 50a01d78-aced-48e7-af09-72a5d92d54f6
Any idea ? Already deleted and reinstalled the App and restarted Homey as well.
Thanks in advance !
Hey @Capetrip
Oh! I already replied to your report
But can you try via the homey web app?
Forgot the image
Hi Martijn,
Thanks a lot ! Through the Web App it worked well !
Thanks again!
Uli
Receiving group messages is no more working. I can send to single person or group without issues, but its not detecting when new group messages arrives.
@Michael_Fritzsche try to repair the device that most of the time solves all issues
already did it… but gave it another try. Does not work. Sending messages works, but receiving group chats is not detected at all.
@Michael_Fritzsche and what about other chats?
Can you send a diagnostic report and also share your flow
