[APP][Pro] WhatsApp, Signal, Telegram, Facebook messenger
You assumed right
I also have the same problems.
If you send a message to the callmebot number +34 644 52 74 88 on Signal, it doesn’t get deliverd anymore. I didn’t get any reply yet. Callmebot is run by only one person, so it might be a while before this gets fixed, if it gets fixed at all.
Yeah, that’s where i got the email addresses from. It’s the first time i received notifications that an email could not be sent with possible causes:
  • Typo in email-address (I used copy /paste)
  • Verify email address exists
  • The recipient is refusing you (what really?)
So that’s why i formulated it like that :clown_face:
I’ve got slight understanding for refusing a known Simple Login domain. I find it harder to believe that an email address from a custom domain would be refused.
But this is getting more offtopic now. Glad to see you and Norbert could send an email :+1:
It’s started working again for me this afternoon.
Yes over here as well :+1:
Confirmed. Case closed I hope :grimacing::wink:
Keep in mind CallMeBot is a one-person-project :folded_hands:
I got this mail:
Hi Bert,
*I’ve started the year with problems everywhere. I can’t wait for it to end!!!
I have been experiencing some issues with the API due to changes on Signal side but I have been working on them and they are now solved.
Thank you for your patience and I apologize for the inconvenience.
Best regards,
Borja*
Why doesn’t Homey send emoticons to WhatsApp anymore? I still see them in Homey. I haven’t received an update.
Edit anwser.
I got a response from callbot. The server crashed frequently due to too much information.
That’s why there are no more emoticons in whatsapp messages. Not problem from Homey.
@Ralf_Huelsmann Thank you for your kind donation. Much appreciated! :smiling_face_with_three_hearts::clinking_beer_mugs:
@Gruijter Hi there! App the whatsapp connection crashed and is not working. Last message I received was on 25 february and the whatsapp device in homey says last seen on 27 february 23:59. Restart doesn’t work. Worked for years and payment is done too. What can I do?
In the logging I see this:
Working nicely on my side.
A few days ago a hickup.
Hi Arjan,
Did you follow instructions?
Like this:
It’s not a generic issue, it works w/o issues here as well:
Haha thanks! The solution was too simple, which made me think that wouldn’t be it. It’s working again.
Hopefully it won’t come back, it took me a month now to notice that I didn’t get the messages. Do you know if there is a possibility to make/get a notification when the bot is paused again?
No problem!
To monitor:
I think the flow card will error when it’s paused or when it’s not functioning somehow: You’ll have to add a error notification to it, and send it f.i. as critical push message:
Feedback here. Requesting to change a couple of lines in readme / text:
The text below is on both forum and github see [APP][Pro] WhatsApp, Signal, Telegram, Facebook messenger - #2 by Gruijter and GitHub - gruijter/com.gruijter.callmebot: Let Homey send messages to your Whatsapp, Signal, Telegram and Facebook messenger · GitHub
See instruction below; that instruction is incorrect.
I would change it (because it did cost me time to figure out the issue).
At method signal you should not include your “phone number”. You should directly use “phone ID” or “phone”.
So i tried to enter:
  • my phone number
  • APIKEY received from signal
Getting error:
there was an error!!! Error Num:2Error Text:Trying to access array offset on value of type null
So use the full long phone=xxx (what is 36 char in my case) ; you need to fill in the xxx as the “API key”
So part:
fill in your phone number and apikey
Full text from the links:
Add the phone number +34 603 21 25 97 into your Phone Contacts. Name it “Homey CallMeBot Signal”.
Send this message “I allow callmebot to send me messages” to the new Contact created (using your Signal Messaging of course)
The bot will answer you with your personal apikey.
Add the Signal device in Homey and fill in your phone number and apikey. You can now start sending messages from a flow.
Thx! Will update the docs.
v2.0.0 is ready for testing:
  • Complete app rewrite.
  • Updated README.
  • Added all translations.
  • Many fixes and stability improvements.
This is a massive rewrite of the entire app. It makes use of the latest Homey and NodeJS features. Many stability improvements were implemented, and errors in image and voice messages tackled (I hope).
Please test the new version and let me know if you find any issues. If all is good I will push it to stable release.
Am waiting to get my API key…
Maybe you need to use “CallMeBot” instead of “callmebot”?
