[APP][Pro] WhatsApp, Signal, Telegram, Facebook messenger
Can you test again with the new version 1.5.1: CallMeBot App for Homey | Homey
I found a small bug that has always been in the code, but didn’t have an effect on older Homeys. But the new Homey doesn’t like it.
v1.5.1
  • Fix adding new devices for HomeyPro 2023.
@Gruijter ,. Thanks again .
Now everything works as aspected on hp2023
Is it a known issue that with the new homey pro 2023 sending snapshots to Signal is not working anymore?
Error message “Invalid App Event: getImageBuffer” in the flow (sending the same snapshot with another app works).
@Gruijter
Edit: this error only happens on mobile. Not in an advanced flow.
Hi, I tried to add a flowcard: send message to Facebook messenger.
Getting this error:
A restart or reinstall doesn’t work.
Diagnostic report:
04259aec-348a-41f4-a617-6a6fa4a51aba
I have also the error; Invalid App Event: getImageBuffer
HP2023, advanced flow and normal flow the same error
Here is another log 5414e525-b2c3-4ffd-bb3a-27b27b7af145
i also get a problem with signal
403:
403 Forbidden
Forbidden
You don't have permission to access this resource.
Apache/2.4.29 (Ubuntu) Server at cmb-app.callmebot.c
i have delete callmebot and instal new and set up but still i get this problem
This doesn’t work for you?
Hello no it dosnt work i have tried it with 3 difrend numbers
+34 603 21 25 97
+34 644 10 55 84
+34 644 56 55 18
Check here for faq and ways to contact callmebot: https://www.callmebot.com/faq/
Hello and thanks for the great APP
since Homey2023 I have a problem with sending pictures
and I’m not sure if it’s up to callmebot or the source of the images
I send a picture from a camera (onvif app) via signal and get an error 403 Forbidden
if I send the same picture via email sender app then the attachment is a xx.bin
this is probably the reason for the error
is there a solution
I found that HP2023 has issues with handling images. Can you try to send the same image to your mobile phone via native Homey Push? If that also doesn’t work, the issue is in HP2023 itself and not the app.
I was able to send the image with push notification with success, but I suspect you are right that the problem lies with Athom
because when sending by e-mail, a file is sent with the file extension bin, but it is a jpg and the signal server will not accept the bin file
I renamed the mail attachment xyz.bin to xyz.jpg and it was the expected image
I have got the same problem after my upgrade to the Homey 2023, with the Send Mail App.
Also receiving .bin files and can rename them to .jpg.
Hello, I have reported it athom but have not yet received an answer on this topic
i just reported it to athom aswell
Problem images with file extension .bin
Hello does anyone already have a solution or answer from Athom
about the problem that images are sent with the ending .bin?
Apart from Athom writing on the error message, they will forward it to the developers, nothing happened.
@meerlol from Athom is looking into the image handling issues.
@Ruurd_van_der_Noord many thx for your kind donation. Much appreciated :heart:
Hey all,
I am trying to set this up and have been hitting an issue. I’m sure it’s me doing something wrong, but I am just not seeing it. At this point I am trying to set up signal.
The steps I am taking:
Install the app.
Restart the app for good measure.
Add the mentioned phonenumber and send the message
I receive the message back and use the test link to check.
The test link sends me a message so all seems fine.
Add a device and choose Signal
Putt in my phone number and the ID I just received.
Click “log in”
I know it says contact callbot support, but since the api test url works fine I cannot really imagine the issue is on their side.
Anyone have a hint on what to do?
Regards,
activ
Okay, so I figured out that it will not work with phone number. There was some sort of userid that I put in instead and then it works.
