[App][Pro]Weather Underground PWS app (Release 4.0.7, Test 4.0.8)
Jes, thanks for de quike and late response.
Je i already have that one, but i tought maybe you know a beter way.
Now there are 2 graphic with differend scaling on the y-as what makes is hard to read.
I gues you know what i mean and how it looks in the wsview app. But as i understand it right there is now easy solution yet to merge the 2 graps on homey dashboard.
I realy like to use one app now i switch between app’s for the forcast and the mesurements from my homebase.
But what is not posible is not posible so is life
Hello Adrian,
I have read some information about the wu forecast widget. Is it correct that I can’t use the widget without a device that used the wu data?
I would like to use the wu widget for a dashboard just for local 5 days prediction off the weather based on my own location. Is that possible? I could only change a station value in the settings of the app.
I believe you will need to provide data to Weather Underground from a personal weather station in order to get an account.
Ow okay, if that’s the issui i could unfornately didn’t use it.
Thank you for the reply!
I have bought a froggit DP2000 7-in-1 Y-editie, wifi/LAN
I have managed to connect the weatherstation into Homey through WU and it’s collecting all data.
But I want to connect the Hub inside Homey because I also have some soil sensors that connect directley through the Hub.
With Misoll and Ecowitt a can not succeed to add the Hub.
Does anybody have this same Hub and know how to connect it in Homey?
There’s instructions in the Misol and Ecowitt app topic. That shows you how to setup the hubs to send data to Homey.
Thanks, I will try to find that :wink:
I have managed to connect the Hub, after that the Weatherstation and after that the moister sensors :slight_smile:
I have done this whit your nice instructions to put the Hub in like this:
Hi Adrian!
I have a small request and wonder if you have the possibility to add the following When-card in a future update;
  • Hours Since Last Rained changed
If possible, please include the number of hours in a tag to be able to use in the next flow-cards.
Thanks in advance!
Hmm, that one is a bit awkward as it is constantly changing. Basically, every time any value changes, the capability is updated with either 0 or the new time since it was last set to zero.
What is you use case for it?
I almost understood that there could be something tricky with this, since the function is available on almost all other values…
I would like to use it to turn a rain pump on and off. Today I have a flow that uses, among other things, information from when it starts to rain and an estimate of the availability of rainwater, some calculations and when it is then time to turn it off. The flow works helpfully today, but things can always be made better… - I think! :wink: So the wish is absolutely not essential.
I think we wait until more people possibly want the same thing.
Have a nice summer! :sun:
Hi
Do anyone else having issues adding a Forcast device? Station device work just fine and I get data but when I try with forecast I get an error that the ID or API key is wrong. In the app log it says Error HTTPS request.
Could you send the app log so I can take a look.
Hi
I have send a diagnostics report with the log d51d11d8-0972-4fb4-8b3e-5ed1f63b1885
The Widget looks really nice on a dashboard .
Hi Adrian!
I can’t quite get this to work;
I want to know what ‘Feels like’ is tomorrow, i.e. in 24 hours. I have then created the following simple flow;
According to the app, the value ‘Feel likes’ was changed to -8 7 hours ago. That is around 09.00.
But the last time the flow reacted is around 20.40 last night according to the graph in Insights and then the value of ‘Feels like’ (the variabel TomorrowFeelsLike) changed from 0 to -1.
I have been following this for a few weeks now and it doesn’t match. The above is just an example.
I don’t even know where to start troubleshooting - or am I thinking wrong somewhere? I would appreciate some help! Thnx!
I made a workaround.
With the above flow I get the correct value, i.e. what is displayed in the app.
I have started to look into this, but it’s one of those that takes time due to the infrequent data updates.
exactly same issue here.
Hi, I recently got a Bresser 8-in-1 weather station, along with two extra thermometers. All the data is uploaded to Weather Underground and displayed neatly in Homey. However, the two extra thermometers are missing from the display; I’d like to use that data in flows. Is it possible to make that data visible in WU? Thanks for your input.
