Correct, the beta version is still overdue to become stable. I am not 100% happy with the new modbus rewrite I did. I have spent a number of hours rewriting it again, just to throw that code away since I was still not happy. Now vacation for a week, maybe I will manage a third rewrite once back ![]()
Hello Richard,
The only thing i would like to read from Victron are the GPS Latitude and Longitude.
Is there a way you kan make those coordinates available?
Try values for percentage betreen 0.01 and 1.00 for 1 to 100 percent. Homey usually uses that internal notation.
Did not help unfortunately.
It seems that homey loses connection with the app after a while. I need to restart the app to refresh the data.
Other app, but want to share I’ve the same issue with modbus and a wifi connected Homey (SMA app, but it’s not an app fault). A user reported it works fine again with an ethernet connected Homey.
How’s your Homey connected @Dirk_vdM ?
It’s connected through ethernet.
OK. You could consider installing Net Scan app to monitor the Homey > router and the Homey > Victron device connections.
Perhaps the connection drops sometimes.
I would like to ask when the new version of the application will be available? The current testing version is very unstable and difficult to work with on a regular basis.
I think it is a bit confusing, wonder who wished for this condition to start with - don’t recall. But this is not comparing agains current SoC, this is checking the “ESS Minimum SoC (unless grid fails)” setting. Since long the built in battery capability is used for displaying SoC.
No thoughts on something similar today. If you have modbus enabled on your GX device an attacker doesnt need to use your Homey - it can go straight to the GX device from anything on your local network.
Athom has updated to the Energy concept and for a home battery we need to provide energy import and exported from the battery as well. Anyone knows which modbus registries we could use for that?
- Imported energy refers to the energy charged by the battery.
- Exported energy refers to the energy discharged by the battery.
New test version has just been released with improved Modbus socket handling. The EV charger has also been updated to comply with the Energy concept.
I don’t think there are any specific registers for Consumed vs Charged Kwh.
In my Home Assistant setup I have to check if reported register is negative then its consumption and if its positive its charging, and do some calculations on that for Home Assistants Energy measuring stuff to get it right.
/Kaj
In the Homey “Energy” section, the “Electricity Total” graph shows only “Imported” and “Exported” data from the grid (blue line), but it does not accurately display the true total household consumption that includes energy from my solar panels and battery (as seen in the attached screenshot). The graph for “Total” seems to be showing only grid data.
How can I configure Homey to display this actual total household consumption data from my Victron GX in the Energy section’s graph, combining all sources (grid, solar, battery)?
Not sure I follow completely, but you need to add to your Homey all the devices from all your providers. If you have energy meter, solar and battery connected in Victron then you add a Solar device, a Battery device and a Energy Meter device using the Victron Homey app and make sure they are included in Homey Energy.
I you scroll up a little you see I asked for cumulative import and export to the battery. If we cant show that we can’t show the complete picture. Seems like Victron doesnt offer that through modbus.
Nope, I hade two before - but there seem to be a problem. Will look into it.
Not sure, but if device id (UnitID) 0 is a known problem. Have been discussed above in this thread.
In general the unit ID will be equal to the device instance, except when the device instance exceeds 247. If the device instance is 0 you can use both 0 and 100 as unit ID. Keep in mind that many modbus TCP clients do not support unit ID 0.
New test version that fixes the problem with multiple temp sensor of the same type. I had assumed the product id was unique but I guess it isn’t. At least not with multiple temp sensors of the same type.
