[APP][Pro] Universal TUYA Zigbee Device App - test
Dropped v7.2.13 on the test channel just now.
Improvements and bug fixes
Covers a huge range of Tuya devices at this point.
@dlnraja I chose wall switch 2 gang 1 way (Bseed) I assume this is the correct one. It still gets added as a generic device, and both buttons activate at the same time. Let me know what information or details you need from me, and I’ll send them. This is driving me crazy.
This is still the TZ3000_l9brjwau TS0002
@Mahom last week, bseed device was known. But now i am same as you.
Finally, a test version that installs and doesn’t crash during installation.
But, the device still has a red exclamation mark. Restarting the app again results in a “App crashes” message.
You changed something in a previous version that made the app unstable, unusable for a lot of users. I read that you a searching for a solution. Keep up the good work. Finish that first before adding new devices and functionality.
EDIT: re-installing the app results again in a time out, see attached image.
Just pushed v7.2.12 to the test channel.
v7.2.9: Nexus Awakening — Stabilized radar presence, added smart humidity auto-correction, and hardened CI/CD for SDK 3 compliance.
It sounds like you’re running into some driver confusion with those devices. In v7+, we made some tweaks to improve the pairing process and ensure that the right drivers are matched based on productId. If you’re still having issues, I recommend double-checking the device type during the pairing process.
I cross-referenced your diagnostics against our industrial schema, and it looks like the app should handle those devices correctly if paired properly. Just remove the device and re-pair it, making sure to select the correct type. This should help clear up any lingering issues. Let me know how it goes!
Hi Dylan Good afternoon, I tried today to repair all my devices I’m on Version 7.2.9 now but non of them I’m getting repaired because of not connecting see screenshots and Diagnostics.
Diagnostic code: 1ea3266b-8156-4bb0-b082-bc5279c0202e
Good luck and thanks for all your hard work,
Regards Peter.
For me it never worked properly. I could only add as an unknown zigbee device and both buttons worked together..What do you choose exactly? wall switch 2 gang 1 way (Bseed)?
@dlnraja Now I tried again on the latest version. Same result.
Hi @dlnraja
I cannot add my ceiling presence sensor; it just adds as an unknown device; please find interview info below:
Summary
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE204_clrdrnya”
“endpoints”: {
“ieeeAddress”: “44:9f:da:ff:fe:62:ee:08”,
“networkAddress”: 65405,
“manufacturerName”: “_TZE204_clrdrnya”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 65405,
“_reserved”: 20,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 81,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
0,
4,
5,
61184
“outputClusters”: [
25,
10
“deviceType”: “router”,
“receiveWhenIdle”: true,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: true,
“powerSourceMains”: true,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“dataTypeId”: 32,
“name”: “zclVersion”,
“value”: 3,
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 1,
“dataTypeId”: 32,
“name”: “appVersion”,
“value”: 70,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“dataTypeId”: 32,
“name”: “stackVersion”,
“value”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“dataTypeId”: 32,
“name”: “hwVersion”,
“value”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“dataTypeId”: 66,
“name”: “manufacturerName”,
“value”: “_TZE204_clrdrnya”,
“acl”: [
“readable”,
“reportable”
“id”: 5,
“dataTypeId”: 66,
“name”: “modelId”,
“value”: “TS0601”,
“acl”: [
“readable”,
“reportable”
“id”: 6,
“dataTypeId”: 66,
“name”: “dateCode”,
“value”: “”,
“acl”: [
“readable”,
“reportable”
“id”: 7,
“dataTypeId”: 48,
“name”: “powerSource”,
“value”: “mains”,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502,
“dataTypeId”: 32,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“dataTypeId”: 33,
“name”: “clusterRevision”,
“value”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“dataTypeId”: 48,
“name”: “attributeReportingStatus”,
“value”: “PENDING”,
“acl”: [
“readable”,
“reportable”
“id”: 65504,
“dataTypeId”: 72,
“acl”: [
“readable”,
“reportable”
“id”: 65505,
“dataTypeId”: 72,
“acl”: [
“readable”,
“reportable”
“id”: 65506,
“dataTypeId”: 32,
“acl”: [
“readable”,
“reportable”
“id”: 65507,
“dataTypeId”: 72,
“commandsGenerated”: “UNSUP_GENERAL_COMMAND”,
“commandsReceived”: “UNSUP_GENERAL_COMMAND”
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“dataTypeId”: 24,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“dataTypeId”: 33,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“dataTypeId”: 32,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“dataTypeId”: 32,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“dataTypeId”: 33,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“dataTypeId”: 16,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“dataTypeId”: 24,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“dataTypeId”: 33,
“value”: 2,
“bindings”: {
“ota”: {},
“time”: {
“attributes”: ,
7.2.9
Hi Dylan, I disconnected and re-paired rain sensors and one soil moisture meter. This works, although initially it is only recognized as a Zigbee device (as is the icon). But the devices have all the essentials displayed, great, that’s the most important thing! Now all that’s missing is the correct icon and the settings the devices actually have, such as rain sensor: Sesitivity; duration until the new LUX measurement. | Soil moisture meters: Adjustment of the moisture level -30 - +30%. Let me know if you need any data. Until then, have a nice Sunday :grinning_face:
34550dc5-63aa-4fb3-9ef1-7c82d062fcc5
This is homey update implémentation not my app .
Hi Dylan still don’t see your new version 7.2.13 it’s still 7.2.9
Why is it no longer possible to re-pair, and why does the Homey Driver appear when deleting and re-pairing?
Working on fixing everything
I need more times
Sorry to everyone.
Okay good luck Dylan CU again later :+1:t2:
Thank you so much for your efforts! Local Tuya devices are a really cool target. :+1:t2::grinning_face:
Good luck fixing everything Dylan! If I can help with anything just ask.
I’m on actual v7.2.9 and just to let you know, it connects now with some devices like the 3 gang usb, but when I click on power on/off it gives me an error.
When I tried to restart the app I had this error on docker:
2026-Apr-12 23:30:50Homey [log][ManagerApiLocal] IO homey:manager:apps:restartApp → Success 204
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:air_purifier_curtain_hybrid Invalid Flow Card ID: curtain_open_partial
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:blaster_remote_hybrid Invalid Flow Card ID: ir_code_received
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:contact_sensor_curtain_hybrid Invalid Flow Card ID: button_pressed
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:curtain_motor Invalid Flow Card ID: button_pressed
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:curtain_motor_tilt Invalid Flow Card ID: curtain_open_partial
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:curtain_motor_tilt_hybrid Invalid Flow Card ID: button_pressed
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:dimmer_3gang Invalid Flow Card ID: dimmer_3gang_gang3_scene
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:ir_remote Invalid Flow Card ID: ir_code_received
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:remote_button_wireless_hybrid Invalid Flow Card ID: remote_button_wireless_hybrid_press
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:scene_switch_2 Cannot read properties of undefined (reading 'registerRunListener')
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:scene_switch_3 Cannot read properties of undefined (reading 'registerRunListener')
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:scene_switch_6 Cannot read properties of undefined (reading 'registerRunListener')
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:scene_switch_wall_hybrid Cannot read properties of undefined (reading 'registerRunListener')
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:sensor_climate_smart_hybrid Cannot read properties of undefined (reading 'registerRunListener')
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:usb_outlet_advanced Invalid Flow Card ID: usb_outlet_button_pressed
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:wall_remote_4_gang_2 Invalid Flow Card ID: wall_remote_4_gang_buttons_2
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:wifi_switch_2gang Invalid Flow Card ID: wifi_switch_2gang_gang2_scene
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:wifi_switch_4gang Invalid Flow Card ID: wifi_switch_4gang_gang4_scene
2026-Apr-12 23:30:51Homey [log][ManagerDriversLocal] onDriverUnavailable homey:app:com.dlnraja.tuya.zigbee:wifi_switch_3gang Invalid Flow Card ID: wifi_switch_3gang_gang3_scene
And this error was trying to turn on/off the 3gang device:
And this error on Wi-Fi Local Tuya:
Hope this could help something.
Dropped v7.2.15 on the test channel just now.
Just pushed v7.2.14 to the test channel.
v7.2.14: Universal Engine Reimplementation stabilization — Repaired 289 drivers, fixed SOS button and Radiator Controller crashes, resolved ASI bugs in flow registration, Added support for Shenzen New Green Energy temp/hum sensors (_TZE284_8se38w3c) thanks to @pemikalsen-sudo, and improved CK-BL702 energy plug support thanks to @john1v.
