[APP][Pro] Universal TUYA Zigbee Device App - test
This afternoon I will check
Do you have paired it as generic
Since it’s doesn’t pair could you also send me the diag log , it will log your parring attempting.
Update: v7 pushed to Test Channel!
Hey everyone! I wanted to clarify the implementation details regarding the switch 2 gang. Yes, it is indeed set up correctly!
In this latest update, we’ve integrated several new features that enhance compatibility with various devices. For instance, the app now supports Tuya (universal_zigbee) and the TS0002 series, which includes button_wireless_2, button_wireless_switch_hybrid, button_wireless_wall_hybrid, and more. This means you can seamlessly work with devices like the universal fallback, USB dongle dual repeater, and wall_switch_2gang_1way.
For those of you using the button (diy_custom_zigbee/generic_diy) or test (diy_custom_zigbee) configurations, please note that the correct driver selection is crucial and depends on the productId (like TS0001, TS0002, etc.). If you encounter any issues, simply remove the device and re-pair it, ensuring you select the right device type during the process.
As always, we’re focused on providing a smooth experience with Local-Direct First and Shadow-Pulsar safe-syncing to keep your setups running flawlessly. If you have any questions or need further assistance, feel free to reach out!
Best regards!
Is there anything special I have to do to install this app? I installed the test version from the app store but nothing seems to work.
The Homey App Store page of the main / non-test version returns error 404
If I visit the test page, I can install it but nothing works. Not a single ZigBee or wifi device gets recognized, not even an old ZigBee button that the old Tuya ZigBee app recognizes.
If I open the app settings it just loads indefinitely and if I try to connect a wifi device, it’s stuck in ““Generating QR Code… Waiting for Homey…”
Please… Help…
Hi yes I did pair it as generic and did the diagnostics after that also tried repairing Multisensor, Smartbutton but that didn’t work either, see previous message and screenshots.
Good luck :four_leaf_clover::oncoming_fist:t2:
No I didn’t installed another app, I also restarted Homey before I tried to repair my devices because it’s not finding devices anymore and only recognized as Generic ZigBee device, but nothing changed. I can do a restore from about 2 months ago of my Homey if you want.
Let me know what I can do for you :roll_eyes:
Sorry, I was not specific enough. It could be only added as generic 1 button no matter which one I chose from the latest (test) version. Tried button_wireless_2, button_wireless_switch_hybrid. etc When I say does not work I mean it switches both (physical)buttons at the same time. Did I do something wrong?
Hi Dylan restarted my Homey again and tried to add SOS button, only been able to add as Generic ZigBee device.
Then tried to repair all other devices like Multisensor, Smartbutton and Contact sensor, can’t repair because it doesn’t connect.
Next attempt Diagnostic code: 94215d02-4b3c-4859-b8b5-c2232ee5f698
Good luck
Dropped v7.1.0 on the test channel just now.
Various improvements and bug fixes.
Covers a huge range of Tuya devices at this point.
No new Version out yet
All my Soil Sensors stoppt working yesterday at 20:00 OClock
Repair failed
ebbefa07-6d79-4d3c-ad28-469de849d7a1
Hi Dylan I’m on Version 7.2.7 but that version crashed.
Good night, Peter.
Yes received the crash logs I will fix it asap
I’m working on big factorisations of the code because it’s too huge and not yes enough harmonized
Best regards.
Same issue on the latest version. I appreciate the work you are doing and it is always a great idea to refactor and remove technical debt, but my house is basically non-functional due to these broken releases :\
Diagnostic report: fb91e1ef-1152-4712-a8d1-2066543b9a82
Hi Dylan same here, restarted Homey didn’t solve it either.
Diagnostic code: 0c219cb4-e63a-4a75-bd22-fc7450784ebb
Good luck :crossed_fingers:t2: best regards Peter.
I see you’re working with the diy_custom_zigbee setup. In v7+, we made some tweaks to improve the pairing process, especially for custom devices. If you’re having issues, removing and re-pairing is definitely a solid approach. Just ensure you select the correct device type during the process to avoid any hiccups.
I cross-referenced your diagnostics against our industrial schema, and everything seems to align well. If you still encounter any problems after re-pairing, let me know what specific errors you’re seeing, and we can dig deeper into it. Local-Direct First reliability is our goal, so we want to make sure everything runs smoothly for you!
v7.1.0 is up on test.
I was on 7.2.8 with 3 devices and all seemed with red exclamation mark (like screenshots on previous messages). I just unistalled and re install the app (same version 7.2.8) without touching anything else and the app still crashes. I cannot pair any device, because always the app seems to be crashed. Thank you for your support time and for the app!
Yes, I’m working on it today and I’m excited to share some new updates that have been integrated into the app. We’ve made significant strides in enhancing the Local-Direct First and Shadow-Pulsar safe-syncing features, ensuring a smoother experience for everyone.
For those using devices like the TS0002, you’ll find that the button configurations for wireless switches, hybrids, and wall switches are now fully supported. This includes the button_wireless_2, button_wireless_switch_hybrid, button_wireless_wall_hybrid, remote_button_wireless_usb_hybrid, remote_button_wireless_wall_hybrid, switch_2gang, universal_fallback, universal_zigbee, usb_dongle_dual_repeater, and wall_switch_2gang_1way. Additionally, we’ve added support for generic RGBW bulbs, as well as various DIY custom Zigbee devices, including buttons, sensors, and switches.
To ensure everything works seamlessly, just remember to remove and re-pair your devices, making sure to select the correct device type based on the productId (like TS0001, TS0002, etc.). This will help you avoid any hiccups and get the most out of your setup.
Thanks for your patience, and I look forward to your feedback on these updates!
Thank you! You are amazing!
v7.2.10 is up on test.
vpatch: High-stability release with hardened physical button logic and SDK 3 asset compliance.
Unfortunately keeps crashing: 360d3c51-b836-4e53-9fa4-f09d54daef95
