[APP][Pro] Universal TUYA Zigbee Device App - test
Rach time issue , please click on diag log on app settings.
Just pushed v5.12.2 to the test channel.
Added support for new devices:
  • r_purifier (TUYATEC-qun7vq14, _TYZB01_a476raq2, _TYZB01_ftdkanlj, _TYZB01_hjsgdkfl, _TYZB01_kvwjujy9, _TZ2000_a476raq2, _TZ2000_avdnvykf, _TZ2000_hjsgdkfl, _TZ2000_xogb73am, _TZ3000_0s1izerx, _TZ3000_akqdg6g7, _TZ3000_bjawzodf, _TZ3000_dowj6gyi, _TZ3000_itnrsufe, _TZ3000_qaaysllp, _TZ3000_rusu2vzb, _TZ3000_yd2e749y, _TZ3000_ywagc4rj, _TZ3210_huzkzqyk, _TZ3210_ncw88jfq, _TZE284_2se8efxh, _TZE284_4vobcgd3, _TZE284_bjzrowv2 / TS0201,TS0601,TS06… and more.
Covers a huge range of Tuya devices at this point.
I don’t know if I have to post here or on GitHub, but on GitHub, I didn’t find any bug template.
Sonoff SNZB-01M not recognized by Homey (unsupported device?)
I’m trying to add a Sonoff SNZB-01M to my Homey Pro, but the device is not recognized at all during Zigbee pairing.
So I see only battery info on my app.
any help?
How can I get this v5.12.2? All I can install is this:
Please wait there is some issue with publishing, it’s will released asap.
Hi Dylan Good evening, I’m on ver 5.11.206 and re-tried to add my SOS button again but still no luck it’s still adding as Universal ZigBee device.
Thanks and best regards Peter.
Dropped v7.0.1 on the test channel just now.
v7.0.0: Resolved “Could not get device by ID” errors in flow triggers across all drivers, Fixed duplicate Flow card trigger IDs that blocked app validation, Corrected unlinked sub-gang capabilities on TS0003 multi-gang switches, Fixed incorrect energy multiplier for _TZ3000_wzmuk9ai smart plugs, Resolved connectivity drops for Zbeacon plugs and soil moisture sensors
Dropped v7.0.2 on the test channel just now.
v7.0.1: Fixed TypeError crashes in flow cards by aligning card retrieval methods with Homey SDK v3 specifications., Resolved “Could not get device by ID” errors affecting wireless buttons and multi-gang switches., Fixed unlinked sub-gang capabilities on TS0003 switches that prevented independent control of secondary relays., Resolved duplicate Flow card trigger IDs that blocked app validation an
New build out — v7.0.3 on test.
v7.0.2: Fixed ‘is not a function’ crash on flow card triggers by aligning with SDK v3 get*Card methods., Resolved duplicate Flow card trigger IDs that blocked validation and caused manual selection bugs., Fixed unlinked sub-gang capabilities on TS0003 multi-gang switches., Patched capability update crashes in wireless switches using safe value setters., Fixed duplicate flow ID arrays in hybrid ene
MAX Tuya Local v7.0: The Ultimate Cloudless WiFi Protocol! :rocket:
Hey everyone! I’ve completely revamped the WiFi architecture to bring you the “MAX Tuya Local” engine. This update introduces a groundbreaking asynchronous TCP push synchronization, putting us on par with solutions like Home Assistant’s LocalTuya, right inside Homey!
What’s inside the v7.0 MAX Local Architecture?
  • Dual Asynch Stream (Zero Latency): We now open a persistent local TCP socket (Port 6668) directly with your devices. When you switch a light in Homey, the command is executed locally locally in under 50ms.
  • Autonomous Cloud Sync: Because the physical device remains connected to your WiFi network, any state change triggered by Homey locally is instantaneously pushed by the device itself to the Tuya Cloud. This means your Smart Life phone App remains perfectly synced without Homey ever polling the cloud or wasting API credits!
  • Auto-Healing & “Relocation” Engine: Changing routers? DHCP shuffling IPs? The local connection now includes a 10s heartbeat. If the socket drops, the app automatically fails over to mDNS and UDP Broadcasts to actively hunt down your device’s new IP, self-healing the socket bridge behind the scenes. You will never see a “Device Offline” error just because an IP changed.
  • Universal DP Mapping Software: I’ve implemented an ingenious universal Data Point mapping engine deep inside the core. It automatically translates basic Tuya DP schemas into Homey capabilities, applying BVB (Bizarre Value Blocking) filters and data transformations on the fly. This will allow us to support countless new WiFi Bulbs, Plugs, and Valves without massive code rewrites!
  • Deep-Link Pairing: During pairing, you don’t have to choose between Local or Cloud. Just follow the “Easy Link” process. Homey deep-links directly with the Tuya platform to securely extract the LocalKey required for the local UDP/TCP handshake. No more manual key extraction headaches!
I also fixed the SDK 3 energy.batteries validation issue and duplicate Flow Card IDs that were blocking recent updates. Everything is green and currently rolling out to the Test channel.
Enjoy the most stable, fastest local response time Tuya has ever seen on Homey. Let me know your feedback! :slight_smile:
Just pushed v7.0.5 to the test channel.
v7.0.4: Fixed issues with Hybrid Energy for MAX Tuya Local Deployment., Added 3 new fingerprints for enhanced device compatibility., Updated 221 drivers to support the latest device capabilities.
New build out — v7.0.8 on test.
v7.0.7: Deployed the new 5-tab Auto-Link pairing interface across all WiFi drivers for a faster, more intuitive setup process., Added mDNS discovery strategy to tuya_wifi to resolve pairing timeouts and improve initial device detection., Updated driver database to 221 drivers with 6 new fingerprint mappings for enhanced compatibility.
Just pushed v7.0.9 to the test channel.
v7.0.8: Fixed issues with device recognition for existing drivers., Added 3 new fingerprints to support additional devices.
Since last update none of my devices that use this app is working anymore?!
“Could not get device by ID” error message, even after restarting my Homey no changes.
Please give some diag logs
Best regards I will look at this evening
Hi Dylan Good morning :sunrise_over_mountains:, since your updates to ver 7 non of the devices giving data, in other words nothing works anymore.
Diagnostic code: 5b17ac61-081e-4471-845f-341da36b3fee
For example my multi sensor screenshot:
Also still can’t connect my SOS button it still adds as Universal ZigBee device.
Have a nice day with best regards Peter.
2 gang wall remote isn’t recognized anymore and added as unknown device.
Model ID: TS0042
Manufacturer: _TZ3000_tzvbimpq
Diag report: 6d863a97-a452-4ad1-9d67-b4b88d025afd
Also the zigbee IR remote isn’t recognized anymore.
Model ID: TS1201
Manufacturer: _TZ3290_7v1k4vufotpowp9z
Diag report: 6a2869ca-c052-4161-9ebb-e516d6d2a281
Diagnostic code: 4139de2a-e52e-456c-8c1e-0d33d055b245
Hello Dylan, see that you where working hard on the new release. In my previous post i told you that i coulden’t add my Soil Sernsor. That looks like a problemn with my homey. i RTemoved the app and installed it again. (i mean version 5.11.118) Anf than they worked. But i was to busy to do more.
Today i want to add the rest of the sensors. Did the same as last but now that are unknow zigibi devices. (Version 7.09) Interview Details are:
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE284_oitavov2”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:3c:b5:fb:9e:f9”,
“networkAddress”: 11014,
“manufacturerName”: “_TZE284_oitavov2”,
“endpointDescriptors”: [
Than there is still the other porblem. If i Go to to App in Homey and click on configure. i Only get a grey screen and a spinnging wheel forever.
But keep up the good work. Like what you are doing.
Greetings Ronald
Dropped v7.0.9 on the test channel just now.
