Latest version: Watersensor still no alarm. Says inactivated. Interview above.
Hi @dlnraja
I have just tried v5.7.35 with my Moes 4 button wireless scene switch. Happily the virtual button continues to trigger the flow. The physical button however is still not able to start the flow.
I have attached a diagnostic within 10 seconds of various presses on button 1. I hope that helps.
087ee80a-f230-4119-af8d-bea3c366755e
Thanks
Fred
@dlnraja now on v5.7.16.
Did check again all the wiring, and everything seems good.
I did another interview as I just change the circuit breaker used as an input for the module. Used the same than measured one.
"ids": {
"modelId": "TS0601",
"manufacturerName": "_TZE284_81yrt3lo"
"endpoints": {
"ieeeAddress": "a4:c1:38:a9:45:fb:a3:2f",
"networkAddress": 17347,
"manufacturerName": "_TZE284_81yrt3lo",
"endpointDescriptors": [
"status": "SUCCESS",
"nwkAddrOfInterest": 17347,
"_reserved": 22,
"endpointId": 1,
"applicationProfileId": 260,
"applicationDeviceId": 81,
"_reserved1": 1,
"inputClusters": [
4,
5,
61184,
0,
60672
"outputClusters": [
25,
10
"_reserved": 10,
"endpointId": 242,
"applicationProfileId": 41440,
"applicationDeviceId": 97,
"_reserved1": 0,
"inputClusters": [],
"outputClusters": [
33
"deviceType": "router",
"receiveWhenIdle": true,
"capabilities": {
"alternatePANCoordinator": false,
"deviceType": true,
"powerSourceMains": true,
"security": false,
"allocateAddress": true
"extendedEndpointDescriptors": {
"1": {
"clusters": {
"groups": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"name": "nameSupport",
"value": {
"type": "Buffer",
"data": [
0
"reportingConfiguration": {
"status": "NOT_FOUND",
"direction": "reported"
"acl": [
"readable",
"reportable"
"id": 65533,
"name": "clusterRevision",
"value": 2,
"scenes": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"acl": [
"readable",
"reportable"
"id": 1,
"acl": [
"readable",
"reportable"
"id": 2,
"acl": [
"readable",
"reportable"
"id": 3,
"acl": [
"readable",
"reportable"
"id": 4,
"acl": [
"readable",
"reportable"
"id": 65533,
"value": 2,
"basic": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"name": "zclVersion",
"value": 3
"acl": [
"readable",
"reportable"
"id": 1,
"name": "appVersion",
"value": 78
"acl": [
"readable",
"reportable"
"id": 2,
"name": "stackVersion",
"value": 0
"acl": [
"readable",
"reportable"
"id": 3,
"name": "hwVersion",
"value": 1
"acl": [
"readable",
"reportable"
"id": 4,
"name": "manufacturerName",
"value": "_TZE284_81yrt3lo"
"acl": [
"readable",
"reportable"
"id": 5,
"name": "modelId",
"value": "TS0601"
"acl": [
"readable",
"reportable"
"id": 6,
"name": "dateCode",
"value": ""
"acl": [
"readable",
"reportable"
"id": 7,
"name": "powerSource",
"value": "mains"
"acl": [
"readable",
"writable",
"reportable"
"id": 65502
"acl": [
"readable",
"reportable"
"id": 65533,
"value": 2
"acl": [
"readable",
"reportable"
"id": 65534,
"name": "attributeReportingStatus",
"value": "PENDING"
"acl": [
"readable",
"reportable"
"id": 65506
"acl": [
"readable",
"reportable"
"id": 65507
"acl": [
"readable",
"writable",
"reportable"
"id": 65487
"bindings": {
"ota": {},
"time": {
"attributes": [
"acl": [
"readable"
"id": 65533,
"value": 1
"242": {
"clusters": {},
"bindings": {}
And here is a diag
e0fcf3c9-89e4-4a92-a689-26f401ba0f50
Also Idid change the ratio on the module parameter to 1000.
Hi Dylan busy bee
you’re still have a lot of work there, first the version 5.7.37 was almost good, only no Humidity and Battery.
Motion was stable together with Luminance and Temperature ![]()
Now it’s updated to Ver 5.7.38 and it’s all messed up again fluctuating Luminance Motion On and Off and no Temperature Humidity and Battery.
Diagnostic code 5bf7923d-e563-4588-8415-3368db7037f1
Sorry that I have to report this again it must be very frustrating for you as well ![]()
Have a nice evening and best regards Peter.
Yes sometime I need to break it to add more devices,I suggest you to disable auto update right now for your case.
Okay I will
good luck.
Hi Dylan,
Any progress on the IR-remote?
With the latest version still nothing. I’m getting error: Missing Capability Listener: onoff
Made a diag report again: df7c5882-0876-4989-a0cb-c2d2cc4eb7b2
It’s not fixed ?
Could you please tell me what’s working or not and what’s happening
Nope, it never worked. Now when trying to turn it on, i get this error:
Learning mode, won’t come on at all.
In reply to your request:
Removed the app and all devices, but still not working :-/ …shows up as generic device:
Zigbee-Gerät Presence a4:c1:38:a8:ad:c4:80:08 49789 (C27D) router 37 seconds ago ✓ _TZE204_ztqnh5cg TS0601 - - -
1a942c70-99d6-4cf2-ad71-e7a860661399
Full interview \_TZE204_ztqnh5cg
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE204_ztqnh5cg”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:a8:ad:c4:80:08”,
“networkAddress”: 49789,
“manufacturerName”: “_TZE204_ztqnh5cg”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 49789,
“_reserved”: 20,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 81,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0
“outputClusters”: [
25,
10
“_reserved”: 10,
“endpointId”: 242,
“applicationProfileId”: 41440,
“applicationDeviceId”: 97,
“_reserved1”: 0,
“inputClusters”: [],
“outputClusters”: [
33
“deviceType”: “router”,
“receiveWhenIdle”: true,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: true,
“powerSourceMains”: true,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 74
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZE204_ztqnh5cg”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“242”: {
“clusters”: {},
“bindings”: {}
The human sensor is now triggering every 5 minutes.
Log: 7570421d-64b1-46b4-ac74-ee02e92bbc58
Hi @dlnraja
The Moes 4 button switch is still not triggering flows with physical buttons with v5.7.52. But virtual buttons still working well. I am appending a diagnostic log, and please let me know if anything else is required.
66fc5dc3-fbea-47bd-a52e-d3569b334c89
Thanks again
Fred
Hi @dlnraja, thanks again for all the work on the app!
I’m trying to add a soil sensor ( _TZE284_oitavov2 / TS0601) but it gets added as an unknown device so just to be sure I interviewed it again:
"ids": {
"manufacturerName": "_TZE284_oitavov2"
"endpoints": {
"endpointId": 1,
"_reserved1": 1,
"inputClusters": [
4,
5,
61184,
0,
60672
"outputClusters": [
25,
10
"endpoints": {
"1": {
"clusters": {
"groups": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"value": {
"type": "Buffer",
"data": [
0
"acl": [
"readable",
"reportable"
"id": 65533,
"value": 2,
"scenes": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"acl": [
"readable",
"reportable"
"id": 1,
"acl": [
"readable",
"reportable"
"id": 2,
"acl": [
"readable",
"reportable"
"id": 3,
"acl": [
"readable",
"reportable"
"id": 4,
"acl": [
"readable",
"reportable"
"id": 65533,
"value": 2,
"basic": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"value": 3
"acl": [
"readable",
"reportable"
"id": 1,
"value": 80
"acl": [
"readable",
"reportable"
"id": 2,
"value": 0
"acl": [
"readable",
"reportable"
"id": 3,
"value": 1
"acl": [
"readable",
"reportable"
"id": 4,
"value": "_TZE284_oitavov2"
"acl": [
"readable",
"reportable"
"id": 5,
"name": "modelId",
"value": "TS0601"
"acl": [
"readable",
"reportable"
"id": 6,
"name": "dateCode",
"value": ""
"acl": [
"readable",
"reportable"
"id": 7,
"value": "battery"
"acl": [
"readable",
"writable",
"reportable"
"id": 65502
"acl": [
"readable",
"reportable"
"id": 65533,
"value": 2
"acl": [
"readable",
"reportable"
"id": 65534,
"value": "PENDING"
"acl": [
"readable",
"reportable"
"id": 65506
"acl": [
"readable",
"reportable"
"id": 65507
"acl": [
"readable",
"writable",
"reportable"
"id": 65487
"bindings": {
"ota": {
"attributes": [
"acl": [
"readable"
"id": 0
"acl": [
"readable"
"id": 1
"acl": [
"readable"
"id": 2
"acl": [
"readable"
"id": 3
"acl": [
"readable"
"id": 4
"acl": [
"readable"
"id": 5
"acl": [
"readable"
"id": 6
"acl": [
"readable"
"id": 7
"acl": [
"readable"
"id": 8
"acl": [
"readable"
"id": 9
"acl": [
"readable"
"id": 65533,
"value": 3
"time": {
"attributes": [
"acl": [
"readable"
"id": 65533,
"value": 1
Ver.584 app has crashed.
Hi Dylan, my device is no no longer recognized by the app. I removed and re-added, but is now a generic zigbee device
@dlnraja All of my devices are munted with 5.8.4 too.
Oppsy sorry I forget an depedency on the new version
RGB / color library
I fix it asap
