[APP][Pro] Universal TUYA Zigbee Device App - test
I installed the app through the app store and this version should include my PR with the switch_dimmer_1gang, but it seems it doesn’t. Could it not be included in the build somehow?
Oh it too bad , do you have any logs please ?
It’s not there entirely. Not even as a selectable device.
Hi @dlnraja
Unfortunately still no progress with the smart button integration, we seem to have gone backwards, in fact!
Currently:
:white_check_mark: Adds as 1-Buttons Wireless controller
:white_check_mark: Doesn’t fire off every hour on its own
:cross_mark: No GUI button in device settings
:cross_mark: No response through flows
:cross_mark: No battery readout
Version: 5.5.759
Diagnostic code: 4d7b45a5-082f-4f1e-a787-a439eac5257a
Hi dlnraja, the thermostat whose interview I sent you a few days ago is now being recognized as such. However, I can’t operate anything. Could you please take a look at it? Diagnostic report attached. Do you need anything else? Many thanks in advance.
TS0601
_TZE284_o3x45p96
fd5b7823-9790-4e3b-910c-5113600b755a
Hey! unfortunately, this temperature sensor is not working since 5 days. Rebooted the Universal App and Homey but when I try to add it again it says unkown Zigbee device.
I would like to ask if someone from the Homey community would be able to add support for the following Tuya Zigbee device.
Device details:
The device pairs successfully with Homey Pro, but no temperature, humidity or battery values are available. This looks like a missing Tuya datapoint (DP) mapping issue.
I found a Zigbee2MQTT issue that appears to describe the same (or a very similar) device: Github
That issue shows the device is recognized, but currently only has an external definition without DP mapping.
Based on other TS0601 Tuya temperature/humidity sensors from similar manufacturers, the DP mapping is usually:
  • DP 1: temperature (integer, value /10)
  • DP 2: humidity (integer, value /10)
  • DP 3: battery (%)
Unfortunately I only have Homey Pro as my Zigbee coordinator, so I am not able to extract Tuya DP logs myself.
Would someone be able to confirm the correct DP mapping for _TZE284_1wnh8bqp and add support for this device to Homey (for example in the Tuya Zigbee or Zigbee app)?
Thanks in advance.
new update now.•
check on the log it’s already on the app, it’s sometimes diplayed on logs on the homey webpages ,some version i skipp to newerversion but fix is included on the code not on the changelog . I don’t relaease each version update on the homey dashboard dev but released the fix is in the app and discribed on changelog file on github project page changelog file.
Ver.769. Water…. installs but no alarm. Thanks.
When I choose the Tuya generic driver, it does install. However, the device doesn’t work.
Screenshot 2026-01-25 at 09.34.37
The device is unavailable and when I try to do anything it says “driver not ready”. Which logs do you want me to give you. When installed through the app store, the options are limited. You you like me to run the master branch in developer mode?
Ok, ignore this. After I ran it once through the dev mode and installed again through the app store, it works fine. I can even select it as a device to add.
what’s dev mode ?
clone the master branch and run it through Homey CLI. The interface then says it’s in ”dev mode”
Hi Dylan Good morning :sun_with_face:, thanks for your update again :oncoming_fist:t2:
But SOS Peter Button readded and still not working, not responding and no Battery reading and SOS Fariba still no response in the Flow.
HOBEIAN Multisensor readded and is added as Motion, Luminance and Distance sensor that’s wrong it should be Motion, Luminance, Temperature and Humidity sensor.
Diagnostic code: 1e2e2f3a-ec1d-4684-b7da-b782af232913
Thanks again for your effort and patience again and good luck with fixing it.
Have a nice day with
Best regards Peter.
Still not working when pressing buttons.
And now also battery don’t show anymore​:cry:
i will check asap, now i re-implement improvements for raw data interpretation. I’ll create a new Universal Raw Data Interpreter that enhances the existing handling and add improvements to the IAS Zone manager for CIE address verification.
Super​:smiley:
Do you need new diag or interview? (have sendt 3-4 times in the last week’s)
Perhaps only new interview
Here we go :slight_smile:
Interview Hobeian
“ids”: {
“modelId”: “ZG-101ZL”,
“manufacturerName”: “HOBEIAN”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:c3:b6:07:9d:f3”,
“networkAddress”: 22996,
“manufacturerName”: “HOBEIAN”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 22996,
“_reserved”: 36,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 0,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
0,
1,
3,
4,
6,
4096,
57345
“outputClusters”: [
25,
10,
3,
4,
6,
8,
4096
“deviceType”: “enddevice”,
“receiveWhenIdle”: false,
“swBuildId”: “0122052017”,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: false,
“powerSourceMains”: false,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“basic”: {
“attributes”: [
“acl”: [
“readable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”
“id”: 1,
“name”: “appVersion”,
“value”: 147
“acl”: [
“readable”
“id”: 2,
“name”: “stackVersion”,
“value”: 2
“acl”: [
“readable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “HOBEIAN”,
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”
“id”: 5,
“name”: “modelId”,
“value”: “ZG-101ZL”
“acl”: [
“readable”
“id”: 7,
“name”: “powerSource”,
“value”: “battery”
“acl”: [
“readable”,
“writable”
“id”: 18,
“name”: “deviceEnabled”,
“value”: true
“acl”: [
“readable”
“id”: 16384,
“name”: “swBuildId”,
“value”: “0122052017”
“acl”: [
“readable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 1
“commandsGenerated”: “UNSUP_GENERAL_COMMAND”,
“commandsReceived”: “UNSUP_GENERAL_COMMAND”
“powerConfiguration”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 32,
“name”: “batteryVoltage”,
“value”: 30,
“direction”: “reported”,
“attributeDataType”: 32,
“minInterval”: 5,
“maxInterval”: 14400,
“minChange”: 1,
“status”: “SUCCESS”
“acl”: [
“readable”,
“reportable”
“id”: 33,
“name”: “batteryPercentageRemaining”,
“value”: 200,
“minInterval”: 3600,
“maxInterval”: 43200,
“minChange”: 5,
“status”: “SUCCESS”
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“name”: “identifyTime”,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“writable”
“id”: 0,
“acl”: [
“writable”
“id”: 3
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“attributeDataType”: 16,
“minInterval”: 60,
“maxInterval”: 600,
“status”: “SUCCESS”
“acl”: [
“readable”
“id”: 16384
“acl”: [
“readable”,
“writable”
“id”: 16385,
“name”: “onTime”,
“value”: 0
“acl”: [
“readable”,
“writable”
“id”: 16386,
“name”: “offWaitTime”,
“value”: 0
“acl”: [
“readable”,
“writable”
“id”: 16387
“acl”: [
“readable”,
“writable”
“id”: 32770
“acl”: [
“readable”,
“writable”
“id”: 20480
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“touchlink”: {
“attributes”: [],
“bindings”: {
“identify”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“value”: 0
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“writable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“writable”
“id”: 0,
“acl”: [
“writable”
“id”: 3
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“minInterval”: 60,
“maxInterval”: 600,
“status”: “SUCCESS”
“acl”: [
“readable”
“id”: 16384
“acl”: [
“readable”,
“writable”
“id”: 16385,
“name”: “onTime”,
“value”: 0
“acl”: [
“readable”,
“writable”
“id”: 16386,
“value”: 0
“acl”: [
“readable”,
“writable”
“id”: 16387
“acl”: [
“readable”,
“writable”
“id”: 32770
“acl”: [
“readable”,
“writable”
“id”: 20480
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“touchlink”: {
“attributes”: [],
“ota”: {},
“time”: {
“attributes”: [],
“levelControl”: {
“attributes”: [],
