[APP][Pro] Universal TUYA Zigbee Device App - test
@dlnraja I made a PR for a separate driver. It works very nicely and I’m happy with this. :wink:
You can, but the 3 backticks need to be on a separate line. This went wrong in the first line;
So, for the first part,
```“ids”: {
you need to put the cursor behind the last backtick and press enter
Then it"ll show as
"ids": {
Thx a lot it’s verry appreciate
Witch ai do you use ?
There is more that 250 files changes, it’s huge.
I will check
I ended up using Claude code and I’m seriously impressed by it. There were some issues to debug, but nothing serious.
Most of those changes are actually in other drivers, because it didn’t get through the app validation. Seemed that multiple other drivers had the same id for the turn_on and turn_off flow.
I did remove the IDs for the devices I’m using from the “dimmer_wall_1gang” driver and moved them to the new “switch_dimmer_1gang” driver, but I don’t know if there are other types/IDs for the same device. I just have these two myself.
Ver.731. water…. installs but no alarm. Hobeian ZG-222Z
Hi Dylan Good day and thanks for all you improvements again, you are doing great :+1:t2:
But not everything is going well at the moment,
the Multisensor HOBEIAN ZG-204ZV is still not sending data from Temperature and Humidity, only triggers movement and giving correct Luminance data, not even after trying to repair it for a few times.
I also managed to add my SOS Peter button again after a lot of attempt’s and struggling to get it paired and where it was showing up as a generic ZigBee device all the time I got it reckoned as SOS button again, but there is no response to the app or to the Flow, noting happens on button press on SOS Peter on the still existing SOS Fariba button in the app it’s getting battery reading and button press activity but in the Flow nothing at all, it all worked flawless before.
Diagnostic code: 55649ae3-2084-4c67-8173-b8ed67fb69a6
Good luck and many thanks again, regards Peter.
Thx for your diag logs
I have add a lot of new devices, that can break old devices
With a max of diag log i can improve algorithm to support every case.
I will check it this afternoon.
Best regard.
Thx​:blush::+1:t2:
Hello Dylan.
Thank you for your hard work. I think it takes a lot of time. I see you make a lot of progress.
But is it possible if you got time to look at _TZ3000_l9brjwau TS0002? There still seen as unknown device.
Thank you very much.
  "ids": {
    "modelId": "TS0002",
    "manufacturerName": "_TZ3000_l9brjwau"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:de:e2:db:1d:0f",
    "networkAddress": 25196,
    "manufacturerName": "_TZ3000_l9brjwau",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 25196,
        "_reserved": 26,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 256,
        "_reserved1": 1,
        "inputClusters": [
          3,
          4,
          5,
          6,
          57344,
          57345,
          0
        "outputClusters": [
          25,
          10
        "_reserved": 16,
        "endpointId": 2,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          6,
          57345
        "outputClusters": []
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "identify": {
            "attributes": []
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "direction": "reported",
                  "attributeDataType": 16,
                  "minInterval": 60,
                  "maxInterval": 600,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "name": "offWaitTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 83
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3000_l9brjwau"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0002"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "2": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 0,
                  "maxInterval": 900,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
        "bindings": {}
      "242": {
        "clusters": {},
        "bindings": {}
And if possible _TZ3000_qkixdnon TS0003
  "ids": {
    "modelId": "TS0003",
    "manufacturerName": "_TZ3000_qkixdnon"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:22:91:d6:dc:67",
    "networkAddress": 22360,
    "manufacturerName": "_TZ3000_qkixdnon",
        "nwkAddrOfInterest": 22360,
        "_reserved": 26,
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          3,
          4,
          5,
          6,
          57344,
          57345,
          0
        "outputClusters": [
          25,
          10
        "_reserved": 16,
        "endpointId": 2,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          6,
          57345
        "_reserved": 16,
        "endpointId": 3,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          6,
          57345
        "_reserved": 10,
        "endpointId": 242,
        "_reserved1": 0,
        "outputClusters": [
          33
    "capabilities": {
      "deviceType": true,
      "security": false,
      "1": {
        "clusters": {
          "identify": {
            "attributes": []
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 60,
                  "maxInterval": 600,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 83
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_qkixdnon"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0003"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "2": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 0,
                  "maxInterval": 900,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
        "bindings": {}
      "3": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 0,
                  "maxInterval": 900,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
        "bindings": {}
      "242": {
        "clusters": {},
        "bindings": {}
And maybe the valve control _TZ3000_iedbgyxt TS0001?
Sorry for the many request. :folded_hands:
  "ids": {
    "modelId": "TS0001",
    "manufacturerName": "_TZ3000_iedbgyxt"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:2c:0d:22:69:81",
    "networkAddress": 39588,
    "manufacturerName": "_TZ3000_iedbgyxt",
        "nwkAddrOfInterest": 39588,
        "_reserved": 26,
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          3,
          4,
          5,
          6,
          57344,
          57345,
          0
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "_reserved1": 0,
        "outputClusters": [
          33
    "capabilities": {
      "deviceType": true,
      "security": false,
      "1": {
        "clusters": {
          "identify": {
            "attributes": []
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": true,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 20480,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 82
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_iedbgyxt"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0001"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
      "242": {
        "clusters": {},
        "bindings": {}
Okay I will check
@Attilla I will also check your new pr.
Sure, thanks!
Hi @dlnraja
Unfortunately Moes wireless scene switch still not responding to physical button press or icon press with version 739. Here is a diagnostic report. Hope it’s helpful.
b0e28de1-86b0-429b-9bcb-3519f0a96bdb
Thanks for the hard work.
Fred
@dlnraja
Hello Dylan.
Tried to include:
BSEED 3 button wall switch zigbee with neutral _TZ3000_qkixdnon TS0003
BSEED 1 button wall switch zigbee with neutral _TZ3000_blhvsaqf TS0001
BSEED 2 button wall switch zigbee with nuetral _TZ3000_l9brjwau TS0002
and valve control _TZ3000_iedbgyxt TS0001 that is seen as a 1 gang smart switch, but does do nothing.
P.S. on version 3.5.759
I sended you a log: f78a7a80-0de5-448a-975e-8ee8d6fc7b9d. Maybe it will help.
Thanks
Hi @dlnraja
just tried my Moes wireless scene switch, and same problems as before with no response to physical or icon buttons. Vetsioy759.
Diagnostic Log
5ce0f2d5-373e-45bf-a541-c3ef0576064d
Thanks
Fred
Hi Dylan,
i recognized your fix with version 750. Now I’m an version 759 and buttons still don’t work. Here a new diag:
da1490f2-0a0f-44f8-a7fd-66eb4f4f3d8b
Best regrads, Hartmut
Ver.759 water…. installs but no alarm. Hobeian ZG-222Z
