[APP][Pro] Universal TUYA Zigbee Device App - test
Ok com.gpm.homesuite/Homey_Interview/4G touch/_TZ3000_lwthnp7j.txt at main · gpmachado/com.gpm.homesuite · GitHub
Hey! Thanks for all the great work. I’m having issues with the TS0044 + _TZ3000_zgyzgdua 4-way switch. Similair to what I read above I doesn’t work with it’s physical buttons (in-app everything works). I got below error regarding the driver. However, it doesn’t matter which device type I select during pairing, I always get this notification.
(Homey Pro 2019 / MOES 4-way switch)
Hi Dylan Good evening, SOS button’s still working fine, only Battery is very Nervous/Glitchy
Contact sensors are not switching open/close but only acting as puls contact, also Luminance is not correct 1st picture is this contact Lum and 2nd picture is as it should be from another type contact/Luminance sensor.
Waterdetector and Smartbutton still not working.
Diagnostic code 0cea6870-69dd-4a98-abdd-e35273699e7d
Good luck and thanks again for your effort Peter.
Hi, I need support for a Tuya Zigbee DIN rail energy meter.
Device:
  • Model ID: TS0601
  • Manufacturer: _TZE284_6ocnqlhn
  • Device: Tongou TO-Q-SYS-JZT
  • Endpoint: 1
  • Clusters: 0xEF00 and 0xED00
  • Universal Tuya version: v9.0.626 Experimental
  • Driver tested: DIN Rail Energy Meter
Homey Developer Tools successfully interviews the device and identifies it correctly as TS0601 / _TZE284_6ocnqlhn.
However, Universal Tuya does not recognize it when trying to pair it with the DIN Rail Energy Meter driver. During pairing it repeatedly detects another device called “Smart RCBO” instead of this energy meter.
Diagnostic report code:
3a1f196d-77e6-44f6-870e-d03d6a28da97
Could you please check the diagnostic report and let me know if this fingerprint can be added to the DIN Rail Energy Meter driver?
Thanks!
You really need to read the first post of the thread.
Hi Dylan Good morning :sunrise_over_mountains: and good News :+1:t2: the Door/Window sensors are fine now, open close is working as on off now and Luminance seems also okay.
Waterdetector is sending puls now when it’s in the water so great work :+1:t2:
Only Smartbutton to fix now because that’s still not receiving data.
Diagnostic code f647d35b-c401-4077-b758-da1356e523f9
Have a very nice day and thanks for fixing so far.
Best regards Peter.
Don’t worry I will check soon . I have also found a new work and will might start in September
Hi Dylan that’s good to hear, congratulations :clap:t2::tada::partying_face::confetti_ball::birthday_cake::clinking_beer_mugs:
Could you re give me all the PID m+mfs name that not fully working on your homey box.
Best regards
Hi Dylan is this message for me or someone else.
Regards Peter.
First of all, thank you for your great work with the app.
I have the latest trial version. Thanks to these, the Moes presence detector was able to connect ZSS-LP-HP02-MS to the manufacturer ID: _TZ3218_t9ynfz4x.
Unfortunately, there is always an error message when saving patamers, such as sensitivity, etc.
Do you have a solution for this?
I use the current Homey Pro mini and the sensor is connected to Zigbee.
Thank you in advance and many greetings from Germany.
Kadir
you :slight_smile:
  1. A_Tas (#2199) : update ≥9.0.651, retester Motion/Static Sensitivity.
  2. meter91 (#2189) : update + re-pair → scene_switch_4.
  3. Toni (#2191) : update + re-pair → din_rail_meter.
  4. Peter (#2190) : re-pair smartbutton (bouton maintenu) + send diag with device info couple. ( pid + mfs)
  5. Gabriel (#2188) : xonfirm pid TS0004 via diag interview.
please do all these and let me know
Hi Dylan good morning :sun_with_face:
I’ve installed the latest version this morning 9.0.661 and I see that the Waterdetector sensor is not connected anymore it says that device is not there because of wrong driver, I was so pleased before that it was finally working after months of trying :roll_eyes:
I also repaired the Smartbutton again but still no response to Homey and his flow.
Diagnostic code 95a7c6e5-969f-4469-be5d-c96b7cb42b60
Good luck,thanks and best regards Peter.
Hi Dylan Good morning it’s me again,
Despite the wrong driver message when opening the Waterdetector it’s still working normal and triggering the flow :+1:t2: so receiving messages when it touches water.
And tried to repair Smartbutton again but still no response in Homey.
Diagnostic code 4b1a0dc9-9fba-4e9b-a85c-66498ab80bc1
Thanks and good luck and have a nice day Peter.
Hi Dylan, first thanks for your good work it helps a lot!
I just opened an issue for a CO2 sensor I just bought (seems its only a misclassification, but it might be more as when i add it to my homey it says I have no app that match the device) : [Bug] _TZE204_ogkdpgy2 (CO2 sensor) misclassified under climate_sensor instead of air_quality_co2 · Issue #531 · dlnraja/com.tuya.zigbee · GitHub
okay i will check
Hi @dlnraja ,
Thanks for looking into this.
I have removed and re-added the device after your update. The device is now correctly recognized as a wall dimmer, however, none of the controls in the app work (on/off, dimming, etc.).
Could you please check again?
  "ids": {
    "modelId": "TS0601",
    "manufacturerName": "_TZE284_m1cvyneb"
  "endpoints": {
    "ieeeAddress": "a4:c1:38:d8:d7:89:0d:43",
    "networkAddress": 53677,
    "manufacturerName": "_TZE284_m1cvyneb",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 53677,
        "_reserved": 22,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 81,
        "_reserved1": 1,
        "inputClusters": [
          4,
          5,
          61184,
          0,
          60672
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "dataTypeId": 24,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "dataTypeId": 33,
                "name": "clusterRevision",
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "dataTypeId": 32,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "dataTypeId": 32,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "dataTypeId": 33,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "dataTypeId": 16,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "dataTypeId": 24,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "dataTypeId": 33,
                "value": 2,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "dataTypeId": 32,
                "name": "zclVersion",
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "dataTypeId": 32,
                "name": "appVersion",
                "value": 78
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "dataTypeId": 32,
                "name": "stackVersion",
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "dataTypeId": 32,
                "name": "hwVersion",
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "dataTypeId": 66,
                "name": "manufacturerName",
                "value": "_TZE284_m1cvyneb"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "dataTypeId": 66,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "dataTypeId": 66,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "dataTypeId": 48,
                "name": "powerSource",
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "dataTypeId": 32
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "dataTypeId": 33,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "dataTypeId": 48,
                "name": "attributeReportingStatus",
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "dataTypeId": 32
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
                "dataTypeId": 72
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65487,
                "dataTypeId": 33
        "bindings": {
          "ota": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "dataTypeId": 240,
                "name": "upgradeServerID",
                "value": "ff:ff:ff:ff:ff:ff:ff:ff"
                "acl": [
                  "readable"
                "id": 1,
                "dataTypeId": 35,
                "name": "fileOffset",
                "value": 4294967295
                "acl": [
                  "readable"
                "id": 2,
                "dataTypeId": 35,
                "name": "currentFileVersion",
                "value": 78
                "acl": [
                  "readable"
                "id": 3,
                "dataTypeId": 33,
                "name": "currentZigBeeStackVersion",
                "value": 2
                "acl": [
                  "readable"
                "id": 4,
                "dataTypeId": 35,
                "name": "downloadedFileVersion",
                "value": 4294967295
                "acl": [
                  "readable"
                "id": 5,
                "dataTypeId": 33,
                "name": "downloadedZigBeeStackVersion",
                "value": 65535
                "acl": [
                  "readable"
                "id": 6,
                "dataTypeId": 48,
                "name": "imageUpgradeStatus",
                "value": "normal"
                "acl": [
                  "readable"
                "id": 7,
                "dataTypeId": 33,
                "name": "manufacturerID",
                "value": 4417
                "acl": [
                  "readable"
                "id": 8,
                "dataTypeId": 33,
                "name": "imageTypeID",
                "value": 65535
                "acl": [
                  "readable"
                "id": 9,
                "dataTypeId": 33,
                "name": "minimumBlockPeriod",
                "value": 0
                "acl": [
                  "readable"
                "id": 65533,
                "dataTypeId": 33,
                "value": 3
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "dataTypeId": 33,
                "value": 1
      "242": {
        "clusters": {},
        "bindings": {}
Hi @dlnraja, thank you for your reply.
I tried adding the switch but it isn’t recognised and adds as unknown zigbee device. I tried all relevant 4-button switches and remotes but it works for all the same.
Don’t know what relevant information i could give from my side at this point. Made a diag report with code c40705a1-9b08-444b-868f-c5a14ca4d2b2
Hello i cannot connect a presence sensor _TZE204_clrdrnya
El Diagnostic ID is 4217d5e3-c845-4f0b-a351-5e5a59295cbb
Thanks
