[APP][Pro] Ugreen NAS - Manage your device locally from Homey!
Hi @RayCokes,
Thanks, and good to be back!
Your screenshot actually tells me quite a bit. The device was added and even picked up its model name (“Ugreen NAS iDX6011 Pro”), and that name comes straight from the NAS — so the login itself is working fine. What’s failing is only the system statistics call, which is why every value shows “-”.
The most common cause for exactly this symptom is the account type: UGOS only lets administrator accounts read CPU/memory/disk statistics over the local API. A regular user can log in perfectly well — you simply get no data back, and no error either. @Tom_ten_Den had the identical symptom earlier in this topic, and that turned out to be the cause.
So the first thing worth checking: is the account you used a local admin account on the NAS (Control Panel > Users), rather than a standard user or a UGREEN cloud login? If it isn’t, create one with administrator rights, then use Device settings > Repair in the new test version to sign in with it — that way you keep your device, Flows and Insights history instead of removing and re-adding it.
If it already is an admin account, then your iDX6011 Pro is likely reporting its statistics in a different format — it’s from UGREEN’s newest series and newer than anything this app has been tested against. In that case I’d like to see what it actually returns: could you create a diagnostic report (Homey app: Settings > Apps > Ugreen NAS > Create diagnostic report) and post the ID here? Also, which version are you on — the stable one from the store, or the test version v1.3.5?
Either way, I’ll change the app so a situation like this shows you a clear message instead of silent dashes.
It’s a local account just for homey, with admin right to test. Rather not have it admin rights. But it’s for the testing.
Repair does not work unfortunately
See screenshot
Gr Raymond
(attachments)
But when I just checked it did the trick :scream::exploding_head::+1::+1::+1::+1:
