[APP][Pro] Tuya Zigbee App
Hi, The _TZ3000_qja6nq5z TS004F Smart knob switch stopped working after one of the recent updates. It was working fine before.
Hi @Mates1134, my bad. Hotfix on it’s way to Test version of the app. Thanks for notifying me!
Hi. I have a _TZE200_crq3r3la, CK-BL702-MWS-01(7016). its a Radar presence sensor. It connected to Homey as a generic device but have the presence triggers. What it does not have is possibility to change settings. Am i missing something or isn’t settings supported when it’s a generic device? Thank you.
Hi
Could you please add support for this Tuya Temperature & Humidity sensor with LCD display? Currently, it gets paired as an Unknown Zigbee Device.
Here are the device details from my Homey Developer Tools:
  • Manufacturer: _TZE284_9em5sfh
  • Model ID: TS0601
  • Device Type: Temperature & Humidity Sensor with LCD Screen
Thank you in advance for your help and for maintaining this great app!
This generic zigbee driver has (very) limited functionality.
You’d best request for having the device added to the app, as per instructions in post # 1 of this topic.
@Kizabgd see instructions in post # 1.
@johan_bendz I have the same issue with the same hardware (Moe’s Smart Knob _TZ3000_qja6nq5z TS004F). With v0.3.4 some functionality has returned but it’s not back to perfectly functioning as it was a few weeks ago. Here are the issues I’m seeing:
  1. The top button works again but it seems like it’s registering extra presses. When I active the flow via the play button in the Homey app it works as intended like before the update. When I use the button on the device it will fade the light on if it was off (expected) but then immediately fade it off (not expected).
  2. The ring/dial around the outside doesn’t work at all now. After the update that broke the functionality the dial only worked when depressed. Now it doesn’t work at all.
As mentioned with #1, all of these worked fine before the update that broke it and also work fine when using the Homey app to trigger the flow. If there’s any extra info that might help you, please let me know.
Thanks for your work on this app.
