Let’s stick to English.
And I think you are better off building your own version of the app
Hi Johan,
I would like to request support for the Tuya Zigbee Pressure/Contact Sensor. Homey pairs it as a generic Zigbee device without functions.
Here are the device details:
> "ids": {
> "modelId": "TS0601",
> "manufacturerName": "\_TZE200_seq9cm6u"
> "endpoints": {
> "ieeeAddress": "a4:c1:38:d1:ee:0b:be:07",
> "networkAddress": 61652,
> "manufacturerName": "\_TZE200_seq9cm6u",
> "endpointDescriptors": \[
> "status": "SUCCESS",
> "nwkAddrOfInterest": 61652,
> "\_reserved": 16,
> "endpointId": 1,
> "applicationProfileId": 260,
> "applicationDeviceId": 12,
> "applicationDeviceVersion": 0,
> "\_reserved1": 1,
> "inputClusters": \[
> 0,
> 61184
> "outputClusters": \[
> 10,
> 25
> "deviceType": "enddevice",
> "receiveWhenIdle": false,
> "capabilities": {
> "alternatePANCoordinator": false,
> "deviceType": false,
> "powerSourceMains": false,
> "security": false,
> "allocateAddress": true
> "extendedEndpointDescriptors": {
> "1": {
> "clusters": {
> "basic": {
> "attributes": \[
> "acl": \[
> "readable",
> "reportable"
> "id": 0,
> "dataTypeId": 32,
> "name": "zclVersion",
> "value": 3
> "acl": \[
> "readable",
> "reportable"
> "id": 1,
> "dataTypeId": 32,
> "name": "appVersion",
> "value": 105
> "acl": \[
> "readable",
> "reportable"
> "id": 2,
> "dataTypeId": 32,
> "name": "stackVersion",
> "value": 1
> "acl": \[
> "readable",
> "reportable"
> "id": 3,
> "dataTypeId": 32,
> "name": "hwVersion",
> "value": 1
> "acl": \[
> "readable",
> "reportable"
> "id": 4,
> "dataTypeId": 66,
> "name": "manufacturerName",
> "value": "\_TZE200_seq9cm6u"
> "acl": \[
> "readable",
> "reportable"
> "id": 5,
> "dataTypeId": 66,
> "name": "modelId",
> "value": "TS0601"
> "acl": \[
> "readable",
> "reportable"
> "id": 6,
> "dataTypeId": 66,
> "name": "dateCode",
> "value": ""
> "acl": \[
> "readable",
> "reportable"
> "id": 7,
> "dataTypeId": 48,
> "name": "powerSource",
> "value": "battery"
> "acl": \[
> "readable",
> "reportable"
> "id": 65472,
> "dataTypeId": 66
> "acl": \[
> "readable",
> "reportable"
> "id": 65487,
> "dataTypeId": 33
> "acl": \[
> "readable",
> "writable",
> "reportable"
> "id": 65502,
> "dataTypeId": 32
> "acl": \[
> "readable",
> "reportable"
> "id": 65533,
> "dataTypeId": 33,
> "name": "clusterRevision",
> "value": 2
> "acl": \[
> "readable",
> "reportable"
> "id": 65534,
> "dataTypeId": 48,
> "name": "attributeReportingStatus",
> "value": "PENDING"
> "acl": \[
> "readable",
> "reportable"
> "id": 65504,
> "dataTypeId": 72
> "acl": \[
> "readable",
> "reportable"
> "id": 65505,
> "dataTypeId": 72
> "acl": \[
> "readable",
> "reportable"
> "id": 65506,
> "dataTypeId": 32
> "acl": \[
> "readable",
> "reportable"
> "id": 65507,
> "dataTypeId": 66
> "commandsGenerated": "UNSUP_GENERAL_COMMAND",
> "commandsReceived": "UNSUP_GENERAL_COMMAND"
> "bindings": {
> "time": {
> "attributes": \[
> "acl": \[
> "readable"
> "id": 65533,
> "dataTypeId": 33,
> "value": 1
> "ota": {}
The device is already integrated into Zigbee2MQTT as “TS0601_bed_presence_sensor”. I found a GitHub Issue containing the exact custom External Converter script where all Tuya Data Points (DPs) are fully mapped and explained:
There is also a Hubitat driver available here:
It would be awesome if you could add this to the test/beta version of the Tuya Zigbee app.
Thank you so much for your support!
Today I wanted to add my Tuya 2 Gang Switch Module with metering. It has been connected before, but lost connection.
While trying to connect, I wasn’t able to doe so. So, what I did: set it to pairing mode, started adding the device in Homey in the Tuya Zigbee app. It had the spinning wheel kind of thing indicating it found the device and was tyring to add it. Then I received an error.
Question: does it have to be in direct contact with the Homey Pro? Or can you also add a device through other Zigbee network devices (if powered)?
AFAIK you can pair through router devices as well, I’ve never had issues with pairing Zigbee devices on the other side of the house at least.
Thanks! In that case something different is happening. It’s not a big issue as I have a Z-Wave switch module in place that does the actual switching. This one is just for power metering
You could try toggling the switch on/off every few seconds during the pairing procedure. Like keeping a battery powered device active.
My experience is that this sometimes also helps for pairing mains powered devices, that take a long time to pair.
So, while it is blinking? Will try!
Yes, indeed
hey johan
can you also add this soil sensor
"ids": {
"manufacturerName": "\_TZE284_myd45weu"
"endpoints": {
"ieeeAddress": "a4:c1:38:c9:a1:3f:38:97",
"networkAddress": 36789,
"manufacturerName": "\_TZE284_myd45weu",
"nwkAddrOfInterest": 36789,
"\_reserved": 22,
"endpointId": 1,
"applicationDeviceId": 81,
"\_reserved1": 1,
"inputClusters": \[
4,
5,
61184,
0,
60672
25,
10
"capabilities": {
"security": false,
"1": {
"clusters": {
"groups": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 24,
"name": "nameSupport",
"value": {
"type": "Buffer",
"data": \[
0
"reportingConfiguration": {
"status": "NOT_FOUND",
"direction": "reported"
"acl": \[
"readable",
"reportable"
"id": 65533,
"dataTypeId": 33,
"value": 2,
"scenes": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"acl": \[
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 2,
"dataTypeId": 33,
"rapportageconfiguratie": {
"status": "NIET GEVONDEN",
"richting": "gerapporteerd"
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 3,
"dataTypeId": 16,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 4,
"dataTypeId": 24,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65533,
"dataTypeId": 33,
"value": 2,
"basic": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"value": 3
"acl": \[
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"value": 80
"acl": \[
"readable",
"reportable"
"id": 2,
"dataTypeId": 32,
"value": 0
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 3,
"dataTypeId": 32,
"naam": "hwVersion",
"waarde": 1
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 4,
"dataTypeId": 66,
"naam": "fabrikantnaam",
"waarde": "\_TZE284_myd45weu"
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 5,
"dataTypeId": 66,
"naam": "modelId",
"waarde": "TS0601"
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 6,
"dataTypeId": 66,
"naam": "datumcode",
"waarde": ""
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 7,
"dataTypeId": 48,
"naam": "powerSource",
"waarde": "batterij"
"acl": \[
"leesbaar",
"schrijfbaar",
"rapporteerbaar"
"id": 65502,
"dataTypeId": 32
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65533,
"dataTypeId": 33,
"naam": "clusterRevision",
"waarde": 2
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65534,
"dataTypeId": 48,
"naam": "attributeReportingStatus",
"waarde": "IN AFWACHTING"
"acl": \[
"leesbaar",
"reportable"
"id": 65506,
"dataTypeId": 32
"acl": \[
"readable",
"reportable"
"id": 65507,
"dataTypeId": 72
"acl": \[
"readable",
"writable",
"reportable"
"id": 65487,
"dataTypeId": 33
"bindings": {
"ota": {},
"time": {
"attributes": \[
"acl": \[
"readable"
"id": 65533,
"dataTypeId": 33,
"value": 1
Hoi Johan
kun je deze bodemsensor toevoegen
"ids": {
"endpoints": {
"\_reserved": 22,
"endpointId": 1,
"\_reserved1": 1,
"inputClusters": \[
4,
5,
61184,
0,
60672
25,
10
"capabilities": {
"security": false,
"1": {
"clusters": {
"groups": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 24,
"value": {
"type": "Buffer",
"data": \[
0
"acl": \[
"readable",
"reportable"
"id": 65533,
"dataTypeId": 33,
"value": 2,
"scenes": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"acl": \[
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 2,
"dataTypeId": 33,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 3,
"dataTypeId": 16,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 4,
"dataTypeId": 24,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65533,
"dataTypeId": 33,
"value": 2,
"basic": {
"attributes": \[
"acl": \[
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"value": 3
"acl": \[
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"value": 80
"acl": \[
"readable",
"reportable"
"id": 2,
"dataTypeId": 32,
"value": 0
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 3,
"dataTypeId": 32,
"waarde": 1
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 4,
"dataTypeId": 66,
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 5,
"dataTypeId": 66,
"naam": "modelId",
"waarde": "TS0601"
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 6,
"dataTypeId": 66,
"waarde": ""
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 7,
"dataTypeId": 48,
"acl": \[
"leesbaar",
"schrijfbaar",
"rapporteerbaar"
"id": 65502,
"dataTypeId": 32
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65533,
"dataTypeId": 33,
"waarde": 2
"acl": \[
"leesbaar",
"rapporteerbaar"
"id": 65534,
"dataTypeId": 48,
"acl": \[
"leesbaar",
"reportable"
"id": 65506,
"dataTypeId": 32
"acl": \[
"readable",
"reportable"
"id": 65507,
"dataTypeId": 72
"acl": \[
"readable",
"writable",
"reportable"
"id": 65487,
"dataTypeId": 33
"bindings": {
"ota": {},
"time": {
"attributes": \[
"acl": \[
"readable"
"id": 65533,
"dataTypeId": 33,
"value": 1
FYI
Even though that is indeed a better way to post interviews, they should be directed to Github ![]()
I want to add a “onomwonden zigbee doorsensor” . This code comes with this equipment:
"ids": {
"modelId": "TS0203",
"manufacturerName": "\_TZ3000_996rpfy6"
"endpoints": {
"endpointId": 1,
"applicationDeviceId": 1026,
"\_reserved1": 1,
"inputClusters": \[
3,
1,
1280,
0
3,
25,
10
"endpoints": {
"1": {
"clusters": {
"identify": {
"attributes": [ ]
"powerConfiguration": {},
"iasZone": {},
"basic": {}
"bindings": {
"identify": {
"attributes": [ ]
"ota": {},
"time": {}
Can this be updates?
This is an English thread. Also read the first post!
Hello @johan_bendz, I am reaching out for assistance with the Zemismart ZN-LRL1E Water Boiler Switch (30A). Currently, the device is not functioning correctly within Homey, as I am unable to see or use an on/off button. Only as generic Zigbee device.
I have attached a screenshot of the device, and have listed the key details below for your reference:
Device Name: generic-ef00-v1
Model: TS0601
Manufacturer Code: _TZE28C100000_rzdkn5rx
Device ID: 2fec90f0-fcf2-47c7-af39-ffce49127b84
Device Profile: zemismart-tuya-switch
Please let me know if any further logs or information are required to help resolve this issue
Did you read the first post of this topic?
I think no one ever does…
Strange. I always start reading at the beginning, not at the end…
Hi @johan_bendz Please add support for this smart button switch:
Manufacturer name: Hobeian
Model ID: ZG-101ZL
Device type: enddevice
Thank you
Please check the first post in this topic on how to request support for devices.
Perhaps Athom can build this in as a default response to a reply to this topic ![]()
