[APP][Pro] Tuya Zigbee App
Succeeded! Thanks I am going to make a GitHub account
I think it is done… I did my utmost! Thanks again for all help and looking forward if this nice PIR sensor with small dimensions and great battery will be suported in the near furure.
@johan_bendz , got a issue with one of the temp & humidity sensor (not LCD).
Got 4 of them:
  1. one of them, sent the info 4 days ago, and to update it is to press the button.
  2. 2nd one updates every 20-24h.
Is there any way that it updates every 5 minutes for example or something like that ?
10x.
Can you try to pair it again without removal ? I got some issues like you described until I paired it again, it was misbehaving. Also check particular settings for device…
tried also without and with removal from the homey, still not working properly.
Zigbee info? ManufacturerName and ProductId?
I have the 4 button switch on several locations at home. Since this last night (update) they are not working anymore.
Normally I need a timer to have them functionally working (one press is always acting like 2 pushes if no timer used) but now nothing works at home anymore.
Is something changed for these switches?
I am running into the same issue. I have a MOES 4 Scene Switch (Product ID:TS0044, Munufacturer ID: _TZ3000_wkai4ga5).
I did notice that the bug pertaining to the unavailability of the long press option has been fixed.
However now none of the four buttons (either via single, double or long press) work anymore: no trigger is generated.
I have re-paired the switch, but that did not solve the issue.
Hi and thanks for the info guys, just trying to kill some bugs and make sure all functionality is in place before pushing the Test version into Live. (long due…)
Have a look here: _TZ3000_wkai4ga5 actions interpreted twice and long press on buttons not supported · Issue #864 · JohanBendz/com.tuya.zigbee · GitHub
A new Test verson is on it’s way.
Thanks @johan_bendz for all your efforts. Is there any information I can provide to help you further identify / test the issue?
I did note something else that might be relevant:
  • The issues with a button press registered twice also relates to the 2 scene (and possible other) versions of this device. In my case, I have the MOES 2 button version: Product ID TS0042, Manufacturer ID: _TZ3000_dfgbtub0.
  • However, this 2 scene MOES device uses the same device ID as the equivalent device from Marmitek. If I pair this switch to the Marmitek app (which supports 1 and 2 button versions of the switch), it works flawlessly: presses are registered only once (and both the single, double, and long press options are available).
If I am not mistaken, you are also involved / contributed to the Marmitek app.
@johan_bendz same issue here. MOES 4 gang stopped working
That’s my app too… I found I did something different in the Tuya app… Let’s continue on github. :slight_smile:
With 0.2.71 MOES 4 gang remotes are working again. But still with annoyng bug Of on/off double click already mentioned in topic.
If you need any kind Of info involved, i can try to provide logs.
Try v.0.2.72
now not working :confused:
sorry to bother in here - seems to work but I have to additional questions:
how long is the press time for longpress? seems very long and is it adjustable?
2nd is it possible to add “longpress release” card
this to be able to use buttons to do blinds up and down :slight_smile:
also for the lora tap 6 btw :wink:
The long press is 5 seconds. That is the time after which the LED indicator light on the button switches off. Also the manual of my MOES device specifies 5 seconds. If you hold it too long (more than 10 seconds), and depending on the button, you enter the pairing mode.
oh so release long press is not even possible I guess - k good to know
Correct. The switch only triggers a press action; not a release action.
With 0.2.73 working flawlessy :heart:
