[APP][Pro] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud
Does the smoke sensor send a message at all?
Connect a timeline card directly to the triggercard, to find out what message is sent by the smoke sensor.
(It will notify of any Raw event, so remove it when done)
Without these kind of check cards, you’re completely in the dark…
You can check what values are being sent at the device debug page of the sensor at iot.tuya.com
@J33bee
Here’s how to re-link with the QR scan:
There is nothing to unlink.
Finally found it… This had to do whit my old config “using” all the datacenters. Pointing to Central Europe (very logical if you are located in Western Europe…) made it work…
No logic thinking, just follow manual :wink::smiling_face::wink:
Something happened a day ago. Tuya cloud app was not able to communicate to tuya cloud. (i wasnt able to manage devices). I uninstalled app and added it back. And I inputed the settings. (username, password, api access key and secret) But when I try to add devices back it keep saying “please configure app first”.
If i put wrong API access secret it will give error: “Error: Error: Code: 1004; msg: sign invalid” And with correct one it says “please restart app…” I am assuming from this that app is able to access Tuya cloud?
Any ideas what is wrong?
Did you check if you need to extend the trial period?
Hi everyone!
Since yesterday all my Tuya connections don’t work.
Been using app on home for a year and a half and it’s been working ok.
I checked if I need to extend trial period and that’s not it.
All devices work fine in the Tuya app but non work I’m Homey.
Seems more people are having issues?
Was thinking it might have something to do with last Homey update?
Which my Homey preformed yesterday at 4 in the morning.
Stopped working yesterday evening. Only one device gives me an error (missing capability listener: onoff). The rest gives no error, just does not work.
All my devices just don’t work.
Did your Homey also update yesterday?
Hi. No update, i’m using Pro 19.
Hi @Peter_Kawa , Not sure what you mean here.
I have these options in Homey and info from Tuya.
Do you mean like image 1 or like in image 2?
Newbee here :wink:
Thanks.
Here also non working Tuya cloud devices. Running a pro '23, but it’s not updated recently.
Tuya app is working fine. Only my mrc floor heating device gives me an error. Other devices (lights) just don’t respond.
Yes it was expired, and now its again valid, and it started to work, thx.
Same problem here with my Duux Edge heating (tried restarting app, re-adding device to Tuya cloud (it is linked), but now the Homey app says: Please configure the app first. The app is configured and logged in though.
Time to replace this thing for once and for all, im switching over to Mill heaters.
All my Tuya devices stopped working since yesterday evening. No response if I manually start a flow.
All dead. Strange. Any clue?
FWIW: my Tuya devices still work. Homey Pro 2023
For the people that have non working Tuya devices: are these sensors, lights or both? I only have lights and an infrared panel heater.
Same problem here. Starting yesterday evening no lights or other device reacting to my Homey. On the SmartLife app everything works.
Same message appears: Please configure the app first. App is configured. I’m trying to extend trial period. Never had to do this before.
Found the option to extend trial period. Strange, the trial period had finished in october 2022, extend in progress or something like that. But till yesterday evening everything worked, so I don’t think that’s the cause.
What do you fill in the different fields?
  • 6 months
  • Developer identity: Others?
  • Project overview: developing items for use in a home environment?
EDIT 1: How long does it take before the extension of the trial period is granted?
EDIT 2: I can’t select any scene in a flow from my SmartLife app, although I selected them before and the scenes are available in the SmartLife app. Seems like the connection between the Tuya Cloud app and the underlying project and app (SmartLife or Tuya) is lost.
me too. last night all Tuya devices stopt working.
in the tijdlijn I got a message: You are still using the old deprecated API and drivers, please switch to new drivers only
Tried removing a device. When I tried to add it again I got the error message “configure app”
That message can have another cause. Check what is in the settings of your app, in the authentication settings section, besides choose the desired api. If there is legacy mentioned, than that can be the cause.
