[APP][Pro] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud
How recent? Doesn’t ring a bell to me…
Have you tried the new Tuya app?
I miss the “Repair” option in your post: did you try to “Repair” one of those devices yet?
Yeah it’s just been updated to address similar issues
I assume @Hugo is using the old “Tuya cloud” app instead of the new one from Drenso? This topic is from Tuya cloud
Could be, but he could’ve posted in this topic by mistake (too many Tuya apps).
Are you using the Tuya Cloud app for Homey or one of the other Tuya apps for Homey?
In case of the former: is your Tuya IoT subscription still valid? It expires after half a year and requires renewal.
If still valid, did you perhaps restrict access to your Tuya IoT project based on IP address (via the IP Allowlist), and your (external) IP address has changed?
Crossed my mind as well, but in these cases all Tuya Cloud app devices become invalid.
Ah yes, that makes sense :blush:.
Yes i tried it some time ago but i have some (i don’t know which once anymore, on the top of my head) devices that won’t work with that app.
Sorry, i tried repairing and it works for a couple of hours. Same as what i already tried.
That is right i do use the old one but with the new settings of Jurgen Heine.
And i renewed my subscription last month, but as Peter says, then all of them would stop working.
When i repair, or when i put my Homey pro 2023 back in factory settings and replace a backup, or replace the batteries.
Everything works, but after a couple of hours always the same devices stop connecting with Homey.
Hallo, ich bräuchte bitte eure Hilfe.
Ich habe das Problem, dass mein Diffuser in der Homey-App nicht gefunden wird. In der Tura-Handy-App ist der Diffuser bereits eingerichtet und funktioniert dort auch problemlos. Wenn ich in Homey nach dem Diffuser suche, wird er allerdings nicht angezeigt.
Ich dachte eigentlich, dass alle Geräte, die in der Tura-App eingerichtet sind, auch über die Tura-Integration in Homey gefunden und eingebunden werden können.
Ich habe auch schon versucht, nach anderen Geräten zu suchen. Dabei werden zwar andere Geräte gefunden, aber leider nicht der Diffuser.
Könnt ihr mir bitte sagen, woran das liegen könnte und was ich machen muss, damit der Diffuser in Homey gefunden wird?
Vielen Dank für eure Hilfe!
Let’s stick to English
Hello, I need your help, please.
I have the problem that my diffuser is not found in the Homey app. In the Tura mobile phone app, the diffuser is already set up and works smoothly there. However, if I search for the diffuser in Homey, it won’t show up.
I actually thought that all devices set up in the Tura app could also be found and integrated into Homey via Tura integration.
I’ve also tried looking for other devices. Other devices are found, but unfortunately not the diffuser.
Can you please tell me why this might be and what I need to do to get the diffuser found in Homey?
Thank you for your help!
Try it with the Tuya app (by Drenso).
https://homey.app/en-nl/app/com.tuya2/Tuya/
Forum: https://community.homey.app/t/app-tuya-smart-life-smart-living/146735?u=peter_kawa
This Tuya Cloud community app (where this topic is about) is “as is”, not maintained.
In case you still like to use it with your diffuser, read this howto please:
Mijn Tuya Cloud-app (versie 1.1.23) werkt niet meer goed.
Bij het bedienen van apparaten krijg ik de melding Missing Capability Listener: onoff. Bij het toevoegen van een apparaat krijg ik Please configure the app first.
De apparaten werken wel via Smart Life. Ik heb de instellingen meerdere keren opgeslagen, maar dat heeft niet geholpen.
Diagnostische rapportcode: 4b37fa45-96e0-45c5-bd0f-55afbada03e0
Ik wil mijn bestaande apparaten en flows behouden en kan de testversie niet installeren als die de huidige versie vervangt.
Is je trial verlopen? Je moet deze elke 6 maanden verlengen op iot.tuya.com
Verlengen is gratis
Ik gebruik Tuya Cloud al vanaf het begin dat ik mijn Homey early 2016 heb. Ik heb nog nooit hoeven verlengen.
Please use English in this English language forum part, thank you.
That’s only possible
  • if you paid Tuya for the IoT Core extension at the time.
    The free to use iot core version will always be a version that needs to be renewed every 6 months.
  • if you were still using the “old” API, and this most probably has now been taken offline for good;
    See the FAQ / Troubleshooting section in post 1 of this thread
My sincere advice:
Migrate to the “official” Tuya app from Drenso (= Athom agent), as mentioned in post 1 of this thread.
You can fix related flows relatively easy by using the “Flow Converter” app.
Pointless, as this app hasn’t been maintained for almost 4y now – please do have a look at post 1 in this thread.
