@smarthomesven
It’s the other way round:
Tuya usually uses figures without decimal points internally
Tuya internal value: 163
Actual value: 16.3
@Calvin
You can consider migrating to the recently added ‘official’ Tuya app by Drenso (Drenso creates and maintains apps for Athom).
You can install the app next to this Tuya Cloud community app, and migrate devices one by one.
I don’t get what you mean by this;
I can connect a Tuya wifi device to 3 platforms at the same time:
Maybe this is a Homebridge issue than, but when I had Tuya connected to my Homebridge and Homey, the logs in the Homebridge constantly said that it can only handle 1 platform and in Homebridge it made my Tuya device not usable. Now i completely switched to Homey and with Homekitty I forward my devices to Homekit. This problem is solved for now
This did the trick. I setup my radiatior in the Tuya app by Drenso and it shows the correct temperatures now! I also see that this app reads much more information and settings of the radiator. This app also allows to adjust your scaling of the setup temperature and the current temperature (1/1, 1/10, etc…) Also this is solved now!
I just took this version because it is the only one that natively supports my shutters, the official one does not support the shutters and yet it is basic shutter switches. So I installed the test version as indicated in the first post, on the other hand I still have this notification that appears "
The app has been updated I think. Weirdly enough all devices I have that are connected through the Tuya cloud app still seem to work. All the ones connected through the official Tuyau app don’t work. Same devices connected through both apps
As I saw your message yesterday I went to check my Tuya Cloud app and the behavior you mention is what I witnessed too… with the official Tuya app, not the Tuya Cloud app. And the solution was exactly the same.
Recently, I’ve noticed that certain devices have stopped responding.
Replacing the batteries doesn’t help.
Re-adding or repairing them works only briefly before they stop working again.
Even resetting Homey to factory settings, re-adding to my network and restoring a backup results in the same issue.
Is anyone else experiencing these problems?
