Good that you have it figured out.
And really appreciated that you got back with HOW you did that!
Hi, I managed to get Tuya Cloud working for my LSC lights. as an alternative the tuya app that not working anymore.
I only recieve push notification on the devices when a certain status changes… which is quite annoying. Have i done something wrong? Or can simply disable this somewhere?
Thanks in advance!
I had exactly the same issue, then i have read somewhere that the password of the Tuya developer account and the Smart life app should not be te same.
after changing my password on tuya, use the smart life app password in homey it works.
Not sure if this help you, as you use the Tuya app, but maybe.
I already had different passwords. Changed it again to be certain. But that didn’t help.
So any other suggestion is welcome!
The app does not configure this by itself.
This is almost for sure due to a flow made by you, which listens to RAW events, and sends every incoming event as push notification, or timeline notifications (and then auto forward as push notifications. But in that case all timeline notifications should get forwarded as push notifications)
With Flow Checker app, you can find out which flows are Tuya flows, by disabling the app.
It’ll show all Tuya related flows as “broken flows”.
Now you’d find the culprit quite easy.
Did you perform the setup-step to register the app with the QR code?
Yes i did
@Peter_Kawa I hardly doubt that since i freshly added these devices… also the flow checker is giving me nothing when disabling Tuya cloud.
If there any other bright suggestion, please let me know! I now disabled the messaged form homey, wich is annoying since i used that quite often
Hello, i’ve got a heating device setup in the tuya smart app, i did everything for the tuya IOT stuff and got the device up and running in homey, yeeey! But in the device tile the target temperature it shows 510°C and it should be 51°C, i would like to adapt the code and run the app in dev mode.
But the app i’m running on homey is called Tuya Cloud v1.1.23. So i went to search the github from homey and found this only.
This is version 1.4.2, and in the description they say it is broken…
Anybody some advice?
is there a way to get a notification for when the developer trial ends, other than everything stops working
I apparently did not encounter this new ‘behaviour’ yet, but today whilst doing some tests, my Timeline also got spammed with such messages. This never occurred before!
(I do not run this Tuya Cloud app often).
The Tuya Cloud app isn’t updated recently, so, that means Tuya Corp. should have changed stuff on their end, which unfortunately is allowed to write events to the timeline somehow.
When applying to the trail you can see how long it lasts. You can put a reminder on your phone or something like I did. Instal HomeService App voor Homey | Homey and put in the date, then you can set a flow card to send a message when the time is almost over.
thanks, i know how to set reminders, I was hoping someone might know how to get tuya to send a reminder
They do, by themselves, by email. But that may change any minute, so I’ve created a reminder flow myself. I always renew the 6 month trail (the longest).
I have never gotten that email
Please search for the workarounds ‘tap-to-run’ or ‘RAW commands’ howto’s in post # 1 of this topic.
Thx Peter,
But this is just returning first device of total of 5. How can i get the flow to check for more than one?
Yw, Zafar.
When you’re referring to RAW commands:
The devices should be operated, or send values, for Homey to receive the events.
