The Atom app also seems to be broken. I managed to add my my HS110 but it displays only power usage, no other details while in the past it dit. My LB130 I cannot add since it doesn’t detect it, while in HA everything seems to work.
Pitty reaction from them are so slow. I see more and more apps dying because of no decent support.
Is anyone actually willing to take over this app ?
The cloud version from Athom is really limited, at least based on HS100 and HS110 - it shows only Watts, nothing more and also relies on cloud reachability, which isn’t good for key workloads but still is great because of options for internal timings.
Sadly enough, no! I read somewhere that a developer was taking over many apps that where not supported anymore by previous developers. But he took on so many, that it almost must become a real job for him. So i don’t think he is intrested in a other one. So i placed a request for this app here.
For me i had 4 TP-link powerplugs (1 HS-100, 3 HS-110). I installed the official athom TP-link Kassa Smart for the HS-100 and replaced the HS-110’s with the “homewizard wifi energy socket”. This energy sochet has a readout every 5 seconds, instead of a readout every 1 minute or more with the HS-110 and the athom official app.
@spkesDE , don’t you want to take this one at least for rewrite ? The code seems to be trivial ;-))))
I wish I would be able to do that but already got stuck on first error when changing the SDK version…
I will buy you a coffee
Well, not knowing what I’m doing (I’m not joking), it seems that HS110 works for me now with “SDK3”. Let’s see how bad it is, but if someone is desperate and using HS110, might be working as well.
Just try it; if it’s not working, try again It’s not magic.
The code may be trivial, but it still takes a lot of work to change everything to SDK 3. Also, I hate to use JavaScript…
Sorry for the late answer, I currently sitting home with pneumonia
Can you maybe point me in the right direction to get my TP link HS110’s working on my new homey pro 2023?
It is the only thing currently that I cannot get to work.
Try to repeat modifications I’ve made, install via CLI and maybe it will be working for you as well.
I would do that myself, but : - don’t have those devices + I’m not developer (it was just luck above)
Thanks for your work. I’ve changed the driver and device files based on your changes. The app is loaded successfully and I can auto discover the light bulbs. (driver.js works correctly)
I have now issues with the error “this.homey.getActionCard is not a function” when I open the device. (device.js seems to have issues).
No idea, as I told you I’m not developer but just looking on my modifications several months ago, should you have this.homey.flow.getActionCard instead of this.homey.getActionCard ?
@anne , hello. It has been 16 days since all tp link devices have stopped working. They are all HS 110 plug. It works the switch (on/off) but not the energy monitoring, strange that all device with the same problem. Homey pro 19
