[APP][Pro] TP-Link KASA LAN - Smart Plugs and Bulbs (WIFI)
I don’t remember if I updated the firmware :cry:
The diagnostic : 9451a3e4-4ac5-4dfb-a942-269a3f8eb24f
Unfortunately I just see in all your HS110 - “TCP Timeout after 10000ms”… so Homey can’t connect to your devices, either because local comm. is closed (VLANs, Wifi client isolations ?) or because of some other problems….
Please see (Deadline February 8, 2021 )Beta Firmware for HS100/HS110(UK) V4 Firmware 1.1.0 ONLY - TP-Link Community but I would be surprised you just updated it recently, as it’s quite old device and also you are probably not UK based.
For me, on firmware version 1.2.6 all works as before.
I see firmware 1.0.5 hardware 4.0.
Another is hardware 1.0 and firmware 1.2.6
I use home assistant before and they break functionalities so ask to have this firmware. I think I can manually flash the device…
So with this is works or not ? It’s the same, which works for me just fine. If not - the problem is not with firmware.
Btw another HW 2.0. and firmware 1.5.6 also works fine…
With this yes
Sorry I see the plug have dynamic up sorry
Yes please, would love to see the KS240 fan/light switch
Not possible without :
Maybe after Athom would bring Python support (in 2026/7 ?) , maybe then it could change… maybe.
Ah that’s too bad - that KS240 really is the nicest one. Good usage, nice feedback.
Heh, care to fork the api repo and own the whole thing ?
Interesting - Home Assistant appears to be able to use it
Cool, so let’s implement it !
I got my KP405 working today in the app, it’s great!
Unfortunately it looks like it only handles on/off and not the KP405’s dimming capabilities? Unless I’m missing something?
Can you send the debug log from the app? I would have to check that, it has been already some time …
@Charles_Spellman please test TP-Link KASA LAN | Homey and provide log/feedback
Version 0.2.44 — Add KP405 dim capability
That worked great, thanks so much!
I created a report - 6efd2fef-ec21-465d-8744-c63b9186e6f0 of it working if that’s helpful.
I’m running into an issue now where none of the devices will connect. I keep getting error ECONNREFUSED with my devices IP address, but the error message shows :9999 at the end, I have confirmed in both the kasa app and the router that the IP address are correct. Have been running this app for awhile with no issues until last night I’m at loss
So what has happened last night?
Which devices, have you tried to restart your router and re-plug your devices? Just by any chance, do you use different or same devices that stopped working? Maybe firmware upgrade happened? … hard to say, really
Nothing has changed that I can see. Nothing has changed that I can control at least. It’s every single Kasa device, not just one, it’s all of them. They work perfectly fine through the kasa app, and Alexa, just not homey. I have verified all the IP addresses match and even tried selecting dynamic IP address and still no luck. I have rebooted the router and homey multiple times, tried restarting the app. I have no idea what’s going on at this point.
Can you send debug from the. Kasa app, despite I doubt that anything points really to the app itself?
Please add support for KS200M motion activated smart switch. Apologies if this has been asked before, i searched but wasnt able to see it. Thank you!
