[APP][Pro] TP-Link Deco
Moin! His name is „Zentrale".
@MathiasT Login issue is back. 84f83bae-b247-4961-86ee-efa9884ce9dc
I see you are on 1.3.0, the main release. try 1.4.22 https://homey.app/a/net.tornbloms.deco/test/
Med vänlig hälsning / Best regards
It worked! Thank you!!
The naming issue should be resolved and some new metrics for the -4G and -5G routers will be included in release 1.4.23. You can find the test here: https://homey.app/a/net.tornbloms.deco/test/
Please provide diagnostics and describe your fault in the provided box when you encounter an issue.
When I woke up this morning I saw all exclamation marks at my Devo’s after the app was automatically updated this night. I removed the app and wanted to re-install and add the Deco’s again but it won’t let me:
86b85a1f-6a4c-4857-8c2d-038101c0493a
What can I do now?
Sorry a new working relese is in the test, please update
No sorry, works like a charm now! Tack sa mycket! (Thank you in Swedish) :smiley:
How does this make sense? On insights it might say something like 12.4 devices connected to the deco?? :joy:
Could be a bad “connection”… :slightly_smiling_face: need to figure out what Home does with the data.
I’m sure you will figure all this out! You’re amazing at fixing the app! :smiley: This app does exactly everything i need. Thank you for making this app!
I think the graph values are like that because Homey calculates average values for the time resolution.
@MathiasT Perhaps setting the step: 1 option to the connected_clients capability will fix the graph. That should indicate for Homey that decimals does not make sense for this specific capability.
Also echoing the praise from the others in this thread :slight_smile: Thank you for all the effort you are putting in for this app. Haven’t had the chanse to check out the test versions for my X50-5G yet but looking forward to it.
Weiterhin Fehlermeldung
Lars, ”still error message” does not help. Please provide more details and diagnostics. And keep konversation in English.
Best Regards,
Mathias Törnblom
Everything still works for me. (Checked yesterday) i’ll keep watching and provide with diagnostics.
Hi
Unfortunally i can not add an device. I get the errormessage regarding Wrangler credentials. I added logging and the report would be
0e2d11de-f278-42a0-856b-208d46a1456d
Any help would be much appreciated.
Best regards, Lars
Hi i see you use the production one 1.3.0. Test this test, 1.4.27 version https://homey.app/a/net.tornbloms.deco/test/
Best Regards,
Mathias Törnblom
Same with Test Version.
Debugginh would be 2e54cf5b-f112-4694-847f-f26f734af8b9
I’m using a TP-Link Deco X75 in Access Point mode behind a Zyxel ISP modem.
The Homey TP-Link Deco app cannot find or connect to my Deco system.
My TP-Link Cloud login works fine (I can access everything in the official Deco app and via tplinkcloud.com), but Homey fails to discover the device.
Homey is a 2019 model
It seems the issue may be related to X75 compatibility and/or AP mode support.
Can you confirm if the Deco X75 in AP mode is supported, or if there is a known limitation?
I do ip adress from the head deco.
Thanks for the log. What device/devices are you using?
