[APP][Pro] TP-Link Deco
Didn‘t work for me as well :frowning:
X50-5G(v2): 61e8bc6e-c2ad-41d6-93c3-0f0ea206f9d3
Grüße, Felix
Can’t even login now
@MathiasT do you have any updates on how it’s going? I’m really excited to see if and how this app works!
try the 1.4.3 relese https://homey.app/sv-se/app/net.tornbloms.deco/TP-Link-Deco/test/
abt pass the diagnostics over.
Med vänlig hälsning / Best regards
Still same problem. 10bafef5-f739-4f6f-8673-d841aae81776
eb0371ca-3187-4603-81b6-036c6395c3b8
using v1.3.0 with my X50-PoE firmware version: 1.5.0 Build 20250619 Rel. 69357
I have tried current prod version on my deco BE65s with same result which I had in december…
Credentials are valid (tested on browser admin).
@MathiasT - There is still my pull request which solves it for me… Pull requests · mathiastornblom/net.tornbloms.deco
Go ahead and use the test version. https://homey.app/sv-se/app/net.tornbloms.deco/TP-Link-Deco/test/
looking forward to feedback and diagnostics
IT WORKED! Thank you! edit: it works, but my deco updates last time 2 hours ago and 3 devices was connected to my deco. Now there’s 15 without the information updating in Homey.
4df97cd9-5950-4d99-a1c7-4abef8d6060f
Also the ONLY device updating is the one with 68.1. The other decos use 71 instead of 68.
Works great here too! Thank you @MathiasT :smiley:
I have my 6 wifi points now in Homey
My X50-5G still does not work - 9ff47ae4-520d-4e39-bc67-3de83b90c23b - but with a different error-Message:
The P9 does exactly the same - 7587de1d-bef2-4831-9130-c6af0d60b26e
Grüße, Felix
@MathiasT The issue was fixed for a while, now it’s back.
b04b025d-22e7-4da8-87e6-afbc24ddf37e
There is a new test build out 1.4.19 https://homey.app/sv-se/app/net.tornbloms.deco/TP-Link-Deco/test/
The issue is that Deco has changed how it responds, and I don’t have V2 units. But with some help and diagnostics, we should be able to solve this.
Hi @MathiasT
Thank you very much for all your effort in supporting us in this app !
Just quick question, do you have to set the username and password the same for every node (the IP adress from the Master) or change it to the IP address of every node individually?
Hi it seems to work great on the master deco! But the other ones doesn’t update values for some reason. (BE65 AND BE22)
b24ef6ec-d9b1-4c8b-b5d3-575ca6600217
:star_struck: they’re found!
First Network (X50-5G is the Master, it’s Name normale is „Zentrale" - but that’s cosmetics) is discovered completely:
In the second Network (only P9s) he also finds all the decos but does not retrieve their names (wich is a minor issue for sure):
Thank you very much, @MathiasT! I’ll start playing with it in the afternoon…
You add the main node; tplinkdeco.net or the IP. Then the app (tp-link account) password. This should give you all the nodes in the add dialog
Best Regards,
Mathias Törnblom
Nice what is the name of you x50-5g? That does not look right :slight_smile:
The decoding seams to have gone of rail
Best Regards,
Mathias Törnblom
Do you think you will be able to fix this? @MathiasT
