[App][Pro]Toshiba AC
Please try the new version v4.2.5 if you have troubles and let me know is this is the solution…
Hi Max,
Starting via advanced flow in V4.2.5. looks oke. All units (I have 8 Kazumi’s) start and status of all AC’s are oke.
But stopping the AC’s via advanced flow did the same as in V4.2.4, briefly stopping (approx. 1 second) , but keeps running, And when stopping a 2nd time via adv. flow it stops without cleaning.
I did 3 seprate tests with all AC’s, but al AC’s do the same.
br Henk.
Here also a manual OFF doesn’t work with 4.2.5. Flap closed for a bit and then opens again, AC stays on but both apps think it’s completely shut down. Dry function will not happen as stated before.
c161b7a4-04f7-496b-ad6f-00075dc6eee8
I finaly succeded to reproduce the issue at my personal homey. After decrypting the communiction from the native toshiba app, and compare it to the calls from the homey app, I found a few suptile differences in parameters and timing.
After that everyting worked fine again.
I’ve pushed the release 4.2.6. to the app store.
Hi Max,
Works like a charm. Thanks may times! You’re the best!
Br Henk.
Oh wow, let’s test! Thanks.
Tested on 2 ACs. First one manual, second one with my flow. Both worked! Log report; c5422949-e585-4629-9e8b-af920f0891e3
If you are able to implement this one also in the next release, it would be great! Thanks again for your continued effort in developing and improving this app.
I have a Toshiba Haori AC (Modell RAS-B13N4KVRG-E and RAS-2M18G3AVG-E) with Pure function. I can without any problem switch between on and off in the Toshiba app (4.2.6) and I have also the choice Pure, Yes or No, when creating the Flow in Homey. The problem is that it does not work with my Homey Pro since the option Pure is not available under devices in the Toshiba Homey app. Is it missing for my specific AC or is it something else? I would really appreciate if this could be solved. Regards / Håkan
This has been solved by WitteKnoll at Pure for Toshiba AC does not function in Homey · Issue #93 · mjilesen/com.toshiba · GitHub
@Max_Westerveld thank you for adjusting the device screen defaulting to Merit B. Now the default setting is MODE (Auto, Cool, Heat, Dry, Fan). Maybe it’s just me but I would prefer defaulting to Ventilator mode, which I use more often than the Cool (summer) and Heat (winter) setting.
Is that possible? Or maybe memorizing the last mode you used?
