managed to reboot the homey, so now it behaves again - but my texts from telegram to the app are not resulting in a response, so here is another report:
835f5648-a21c-4914-86ab-b43a1cd7dbc6
as for the development and time, if it is good then its worth waiting for - no rush and and thank you for looking into it =)
im at work but just had to test it - set it up with e keyphrase received to trigger the question using a logic block, then question is sent, bot reverts back with two options - pressing one of them triggers the action just as I expected so out of the box - this seems to work very good. I will try to test some more tonight, testing different approach - with above I had to create three flows Question and two lines with the expected / potential answer with an action linked to each of them.
This is very good indeed and make the interaction with the bot to trigger stuff so much more user friendly (wife acceptance factor increased).
EDIT: Edit function will be very useful - managed to replace my current “menu” with question cards, and see as the menu will progress / evolve, re-order or renaming will be very useful. For now - have 7 buttons and for now all works very well.
And this flow ask if I want to close my shelly shutters when I’m not home and the sun is going down.
Of Couse with multiple options: Fully down, Fully down beside my kitchen window or just halfway down
The edit feature will come. I’m but not sure if I’ll make a UI for re-ordering the answers. But you still can do it manually. And I was thinking of a option of to enable/disable hiding the buttons after the use, but this will cause a little problem when you re-order the buttons since the ID’s doesn’t match then anymore.
Well, thats why I’m doing it. Its my hobby I have currently 4 days off between two shift blocks and my girlfriend is working, so I have time for my hobby. So everything is fine
If I don’t notice any errors in my coding or get any reports of something buggy I think I’ll sent the current beta into review on sunday.
visually looks fine - have not changed anything - looks fine, tho I miss some descriptive info, but I guess you will include that in the app description with the other stuff
first of all, thank you for your code
I’ve installed your app and configured it. Now I’m able to send a message if something happens… I recive the notifications.
I would like to know if I can use this app to activate some action if I write a specific message to my bot
in example
I send a message “turn on the lights” to @MY_TG_BOT > homey turns on the lights.
At the moment I can activate a flow nomatter what I write in the message
You have to enter the question first inside the settings page where u have setup the token. Then you can select at “2” the questions where it currently says “No result”. Maybe @ilpaolino can help you better. He can speak Italian.
