[APP][Pro] Tapo - Local Tapo devices communication
I just waited even longer and suddenly i was able to connect them.
Or else if your able to connect them to Alexa, you can connect to them threw the Alexa App that just started working again.
I bought the TP Link Tado 100 Smart Motion Sensor. Is it possible to integrate it with the Homey Pro?
App seems broken. All my P115’s stopped responding. Once saw a 403 error suggesting this has something to do with authentication.
Hello I have 3 Tapo C200 cameras. They work like a charm in Homey. I get alarms and live feed. I am wondering if anyone has been able to change the “privacy mode” from a flow in Homey on the C200 ? This would be a great thing since I am running Heimdal and want to set this option on Armed and disarm flows :slight_smile: . I can set it manually from The Tapo App but cant figure it out from the Homey flow. I have not run script that much in Homey but if this is an option that would be great.
Is it possible to integrate the Tapo D210, not for the video stream (not possible due to battery power) but to start a flow when someone presses the doorbell button?
or is this perhaps possible with an H200 or H500 hub and connecting it to Matter?
Hi There,
Just installed 3 P115 plugs without any problem. But then the fourth. Adding in the tapo app is no problem, but adding in the Homey pro gives an error with the text that a KLAP protocol is ‘preventing the addition in Homey.
Google “says” its a protocol layer for more security. However, i cannot in no way add the plug to homey. Has someone the same experience and knows what to bypass?
Few hours later……
Aahhhhh after some more browsing en testing i found the bypass as provided bij Sven_Tegelmo. It resolved my prob.
”My workaround was to enable third party integration in Tapo (not sure if this was necessary). Disabled “Enable local API connection”. Restarted app. Enabled “Enable local API connection”. Restarted app.
Now is it working fine.”
Hi, I have a C530WS. Any plans for support for this camera in near future?
Estoy tratando de agregar el dispositivo P110M y no me lo permite, me podria ayudar con el problema
Traduccion ingles:
I’m trying to add the P110M device and it won’t let me. Could you help me with this problem?
@JChongKoon
Please translate your post, since this section of this Community is only English :wink:
Hello ,i got the tapo l430c any plans to add this?
Thank you
I have problem adding my P110 .. is it because my homey is not connected over wifi but on an ethernet connexion ?? Can you help ?
Tried to add it with the “other app” . I managed to add the plug but no informations are available in homey… They are visible with tapo app…
How did you add them to Homey? For me it just says “No cameras found on the network”.
EDIT: :white_check_mark: I got it working after adding “Camera Account” in the advanced settings section of the C200 in the Tapo app.
