Hi all,
I’ve created a Homey app that integrates weather data from MeteoSwiss
. MeteoSwiss has a roadmap that will have more data available gradually. My goal will be integrating this in the future and to create appealing dashboard widgets.
User manual: https://homey.orangeframe.ch
App current version: v1.1.64 (live)
What does it do?
This app brings Swiss weather data into Homey, including:
Current weather conditions
Forecast data
Possibly warnings / alerts (depending on implementation)
Data from official Swiss weather services
MeteoSwiss is the official Swiss meteorological service, providing highly accurate forecasts and environmental data.
Features
Real-time weather updates
Beautiful widgets
Local forecasts
Integration into flows
Reliable government-backed data
Changelog
Bug fixes
- v1.0.59 Current weather widget: prevent overlap of text and icon
- v1.0.48 Current weather widget now shows: “Clear” at night instead of “Sunny”
- v1.0.47 Memory optimization: ~20% reduction ; and fix for memory creep
- v1.0.2 Weather warnings in correct language. Fixed location lookup timeout on startup.
- v0.0.323 Weather warnings are now displayed in the correct language (German, French, Italian or English)
- v0.0.245 Homey location → PLZ
Added
1.1.64
- New flow condition: “Rain is expected within the next … hours” — ideal for irrigation and watering automations
- Widgets redesigned for a cleaner, more compact look that follows Homey’s light and dark theme automatically
- Widget text now scales correctly with your device font size and no longer gets cut off
- Widgets no longer briefly show “No data” after an app update — a loading spinner appears until they are ready
1.1.45
- Map widgets recover instantly after reinstall (no more blank “No image” while the version cache rebuilds)
- Lightning widget redesigned to match the standalone Lightning Detector app, with sound-wave rings and a 30-minute strike timeline
- Lightning widget now stays visible when Homey’s location is outside Switzerland
1.1.42
- Fixed CPU and memory crashes on app startup (capped weather-map image cache, eliminated competing forecast fetches between widgets)
- New weather-map types: Rain Forecast 4h/12h/24h, Cloud Cover Switzerland, Snow Line Switzerland
- Coprocessor maps now share a styled basemap with terrain shading and lake preservation
- Settings: pairing token autofills after subscription so cloud setup completes automatically
1.1.41
v1.1.0
- Enhanced Maps cloud service: animated precipitation radar with lightning overlay, 5-hour rain forecast from ICON-CH1, wind direction maps, hail probability and hail size maps — all rendered from rawMeteoSwiss Open Data.
- New map type: Rain Forecast in the weather map widget.
- New flow triggers: hail alert started, hail alert ended.
- New flow conditions: hail active, hail probability above, hail size above.
- Pollen widget with nearest MeteoSwiss station data.
- Zero-degree widget: improved mountain silhouette reliability.
v1.0.47
- Current weather widget: canton coat of arms, weather condition text, improved layout
- 9 global flow tokens
- Hourly widgets: precipitation bars with toggle
- Hourly detail widget: sunshine bars with toggle
v1.0.10
- Weather map widget: 15 map types. Current weather: MeteoSwiss icon descriptions. Night moon icons.
v0.0.322
- Fixed dark mode toggle on all widgets.
- Current weather description now shows rain, snow or sleet based on MeteoSwiss weather icons.
- Smoother temperature curves on hourly widget.
- New zero-degree level widget with interpolated value, elevation line and history view.
- Removed discontinued pollen map.
- Various label readability improvements.
v0.0.245
- Dark mode color change
- Switchable custom label in the forecast widget (location)
- Place name lookup from PLZ
v0.0.210 New flow cards for wind, rain probability, sunshine and precipitation.
New Hourly Detail widget with wind direction, speed and sunshine bars.
Improved current weather descriptions using 10-minute precipitation data.
v0.0.193 Added dark mode support for widgets (default light mode to match MeteoSwiss, it does not switch automatically with the Homey setting)
v0.0.190 First beta release
Known issues
- none
Feedback
I’d love to hear your feedback:
- Bugs
- Feature requests
- Device support ideas
- Flow use-cases
This app is a hobby project, built with a lot of curiosity, coffee, and late-night tinkering
I’m creating and maintaining it in my spare time, mainly because I enjoy it and love sharing it with the Homey community.
If you like the app and it makes your day a little easier, consider supporting the project with a small donation. It’s absolutely not required, but always appreciated — and it definitely fuels future ideas and improvements ![]()
Thanks for using the app and being part of the community! ![]()
