It does, thanks. Very cool project, lets see how it works in my home
The versions that I am running is:
- Homey 4.2.0
- Sure Petcare app v1.0.14
On the Sure percare app when i go to configure I still have the turning circle.
But in a flow it is working an closing and opening the lock.
I can login to the https://www.surepetcare.io/ app without any problems
That an old version. I think that issue is already resolved. Please try to update to the latest version: 1.0.22.
There was an update last week (maybe 2 weeks ago). Works fine here…
Dog and cat coming through the pet door -> GTTS over nest mini let’s us know when the pets are coming and going… Cool app (kudo’s to the dev)
And Heimdall goes from armed to partial armed when cat enters…
I cant login. Keep getting “cant read property of location (null)”.
284f6d6d-743e-4017-a49e-6674e6891ba0
// Peter
It goes wrong when the app tries to get the user image. I’ve add a bugfix for that on 1.0.23 (test). Can you try that one?
Thanks!
Sorry, but similar error regarding another variable. HasOwnProperty.
1c4529e9-9f75-4cb1-9ed2-6a8bac678179
My bad. I didn’t test it properly. I’ve added a bugfix for the bugfix in 1.0.24.
Thanks @Koktail!
It works as a charm now!
Possible to add an «and» card?
«A specific cat is home»
«A cat is home»
«Then» card can ex set Heimdall from armed to partial armed
That can be added. I do however not have the time to do so. I’ll add your suggestion to the issue board.
Hi
The app suddenly stopped working and I get
„request failed with status code 401“
in config tab. Restart didn‘t help.
Using v1.0.24 on homey v5.0.0
Someone else having this issue and/or a solution for that?
I’ve seen that behaviour before on v5 (sdk3). I’m currently investigating the issue.
I’ve just release version 2.0.1 to test. In this build i’ve resolved the issue that the login didn’t work.
Can you test if it works?
I’ve just release version 2.0.2 to test.
v2.0.2 - 21.02.2021
- add trigger card: Bowl has been refilled
looks good! thanks for the fast update
I have a problem with the flap often not locking in the evening and not unlocking in the morning. I’m not sure if this is triggered by homey or if the flap locks just don’t work anymore. I use the homey petcare app only to register when the cat is leaving or getting home.
Anyway, I replaced the batteries with fresh ones just two weeks ago… tested them today; it has 5.4V which is pretty low after only 2 weeks. It reports the batteries capacity to be at 45%… Does the homey app perhaps continuously polls status which increases power usage?
So, to all cat flap owners: how long do the batteries last in your home? And how do you control the flap, scheduled from the original app or do you use homey?
Had the same problem, check your wifi, nothing to do with Homey!
No wifi is used in this setup(except for homey which does never show any problems with wifi).
Today I opened up the housing and cleaned it. It was pretty dirty inside (the wind pushes rain and mud up to the flap), hopefully this fixes things. It looks like the blocking pins worked easier after this.
