[APP][Pro] Sun Events - Triggers you at certain positions of the sun
The only reason I used the “time” card is that I want the flow to run only in the afternoon. The sun reaches the same altitude twice a day (except at noon). I’ll try the “between” option, since the issue is probably that the flow misses the exact “22” value, but I’ll still have to limit it to afternoon only. I originally avoided the “between” option because I didn’t want the flow repeatedly spamming the blind for all values within the given range. Thanks for the input.
I think the issue is probably that the flow misses the exact “22” value, so sometimes it works and sometimes it doesn’t. I would probably have to be checking every 1 second for that exact value, which feels a bit unnecessary so I’ll try the “between” option as suggested in the other reply. Thanks for you prompt answer.
Ah yes. My bad, I somehow got ‘azimuth’ in my head instead of ‘altitude’.
Hi Alex,
You could go to the app setting and set there the the value there. This will give you your personal event and no need to check as in summertime when the sun is very low not sure if it matches after 13.00. But I live in the Netherlands so that might be different
Hi @MarcelT, have you had a chance to review my query?
I’ve just confirmed that not only do the Times in the app setting span a two calendar day period, but they are updated before all events in that period have occurred.
For example, today the Times have been updated starting from Solar Noon on the 13/02 through to the Morning Golden Hour on the 14/02. However, the update to the Times occurred in the app before the events from at least Dawn through to the Morning Golden Hour ends had occurred on the 13/02.
I assume this isn’t an expected outcome and I’m guessing is the result of a scheduled update (possibly at midnight) to Times based on my timezone (I’m in AUS GMT +11) but the date/time calculated for the events in my location are calculated from GMT +0 and then adjusted to my time zone (i.e. in my location Solar Noon would be the first event to occur after midnight GMT +0).
Can you confirm the above or share what might be causing the issue? Also keen to understand if the bug can be fixed and when.
Thanks.
Always difficult time zones. Please could you create a case here: GitHub · Where software is built
Describe the situation clearly and add some pictures that helps me a lot. Then I will work on it in the weekend and see if I can get it solved. I know we talked before but I can not recall it exactly.
I think a bug has crept in with the latest update. Circadian level is not updated. When restarting the app, I get the message that it is not installed.
You mean the 3.0.3 release? Could you create a bug on github and of possible logging / screenshot 's? Thanks
It is indeed 3.0.3. I just happened to restart the Homey. That seems to have helped. I’ll see that tomorrow.
Currently trying to identify, why this trigger is not working
Blinds_delay_sun is currently a variable 0-80 minutes.
Any idea if this is supported please ?
This a known issue where i have created a case several years back at homey. Vars as parameter seems not to work (always). I am not sure if it is fixed and i need to change my code but i havent heard back from them. Even after several reminders.
Case at homey: Tag is value is not available as argument in trigger · Issue #204 · athombv/homey-apps-sdk-issues · GitHub
Hi is anybody facing the same issue?
After updating to version 3.1.1, my existing flows started being disabled with the following error message:
XY has been disabled, because the Flow executed too many times (homey:app:com.cyclone-software.sunevents:azimuth_change).
I created a bug ticket: Azimuth change executed too many times error · Issue #125 · magtimmermans/com.cyclone-software.sunevents · GitHub
Thank you
Heszi
Yeah i have the same problem.
Hi, I have the same problem as you
Could you please check the test version? Link on github.
Hello @MarcelT same issue still is happening since v3.1.1 and now in v3.1.2, my flows are getting disabled with the message: “flow x” has been disabled, because the Flow executed too many times (homey:app:com.cyclone-software.sunevents:azimuth_change).
Version 3.1.3 is underway (available in test) and should fix this issue. (At least at my place it is working)
Yes so far so good with the test version. Big thank you.
It seems that the times in event triggers in flows are not updated daily causing flows not to start anymore, or at least not on the right time. For instance sunrise or sunset times.
hey @MarcelT ,
I have a question. Is there a technical reason why offset is limited to -240 through 240 minutes?
I created this flow to control my grow lights in my greenhouse. I want my grow lights to follow the natural sun light as much as possible, but with a minimum amount of hour of daylight.
The lights turn on when morning golden hour ends, and turn off again when evening golden hour starts, unless this equals to less than the minimum hours of light required. This is the flow I created:
With the Current limit of -240 to 240, I’m only able to extend the lights to 8 hours. I want to be able to extend this to a minimum of 10 to 12 hours. As noon remains roughly at the same time where I live (The Netherlands), I’m probably also able to calculate it with time events, but it would be a bit more difficult because of daylight saving time. Is it possible to allow bigger numbers for the offset?
