[APP][Pro] StecaGrid - Get your data from your inverter right into Homey
Oh ok. Maybe every 10s. Moreover I don’t get the errors from the inverter. High voltage AC and relais fails.
But nevermind I see your code is in github will fix it myself.
Hi @Jeroen_Tebbens
Just pushed a minor fix. BUT when tested local, i had the interval working. Have you tried to set the interval to 10 in the settings of the app and restart the app?
I am able to get interval of 10-seconds, by setting the value to 10.
Found it let me try.
Ok that works, missed that setting was there and not on the device itself.
Thx
Hi @Kim_Kokholm yes, but both versions don’t seem to work
Is this working: http:///all.xml
? If so, please paste the result.
does something, not sure what:
3050161816036249815487226275991437279102402311147771224858410012428290000002405921506984296532825400013717296220139173299161040302868540000000000032403708662150001530487007145960000001145567545805740000034531096718149889557666000001343410466058555674512000014239415914652781091102000009409639650317112343900
Are you familiar with postman or other rest clients by chance?
@Kim_Kokholm No not familiar with that, just a beginner, I could try it though
I just realized that my previous post got wrongly formatted.
Do you know the correct ip of your converter? Yes, since you can get the screenshot.
In my case, the ip is: 192.168.1.81. Please try the following in a browser.
Is one of the following working for you:
http://192.168.1.81/measurements.xml?
http://192.168.1.81/gen.screenshot.bmp?
http://192.168.1.81/all.xml
Not working for me:
http://192.168.1.81/gen.yield.day.chart.js?
http://192.168.1.81/gen.measurements.table.json
Adding http://192.168.178.66/all.xml to the app ( with my correct IP) seems to work, no error message ! Correct reading on the total energy ,shame there’s no sun now. Will test asap.
Thanks so much @Kim_Kokholm … !
So supports Stecagrid 3600 !
@Menno_Feitsma TY for the dono! Happy holidays.
@Kim_Kokholm Great app that has been working flawlessly many years already.
However I have a question regarding new feature. Right now Homey (or rather the app) is only able to display energy which is the totalt energy the inverter has produced since new. I would like an option where it would be possible to show watt instead but this is not possible today.
Hmmmm
On my screen:
You doint this from the browser right?
I am not seeing the TOTAL production as on you screen - using the webapp.
Thanks for your reply. I am missing the option “Effekt” w. That is what I am looking for.
I only have the uption kWh under statudindicator and I want the option Effekt as you have shown in your screenshot.
What version of the app are you using and your screenshot - which device?
The app version is v.1.1.11 and I have two different inverters, one StecaGrid coolsept 2500 and StecaGrid coolsept 2000.
Do you need any information from me or any input in order to see whether this is possible or not?
I think you need to re-add the device. Nothing has changed.
