I asked about allowing Sonos speakers long time ago. Did you ever find a solution? Or will it not be possible?
As mentioned (somewhere) in this thead I’ve had some success with Sonos and (was) planning on adding support but without any vision on the ETA. As I don’t have a Sonos device anymore that’s paused until further notice.
Ahh, alrighty! Thanks!
Reading back my own posts: if you created your API token after nov 2024, that’s most likely the issue. See Introducing some changes to our Web API | Spotify for Developers
Thanks for the reaction!
If I recall correctly, I did create the API token after November 2024. Is there any way I can verify that?
Does this mean that Spotify Connect no longer functions properly on the Homey Pro, or is there a workaround if the API token was created after November 2024?
See this post.
Honestly I have no idea if there is a way to check when the token was created. Maybe there’s a tell in the developer portal of Spotify or an e-mail you received. But the thing is: Spotify limited API tokens after Nov 2024 which caused playlists like Discover Weekly stop working. The rest of the app is still working.
A workaround could be to find the playlist ID yourself and use that as input to one of the flow cards.
