I have a solution if you have iPhone. But you would have to do this on every single device you use to connect to the Arc Ultra as this uses Apple’s SHORTCUTS app.
Make a variable for Bluetooth connection, make a flow setting the variable to yes. On iPhone make a automation in the shortcuts app and make a new one with bluetooth.
Now make the shortcut start the flow to set the variable to yes.
If this solution won’t work out for you. Then we’ll hope @xiutit can do something.
