[APP][Pro] Skoda
Hello guys,
I’ve done some tuning towards the authentication and error handling in v0.3.1 (available for test), at least for me the connectivity works again properly now. This should also fix the issue reported by @Marcel_Vellekoop .
It also adds the possibility to start the air conditioning of the car to a certain temperature from a flow. Be aware that your car needs to support this, if your car does not support it, the flow won’t work.
Enjoy,
First of all, thanks for your effort!
After installing v0.3.1, I do indeed see more data.
What should trigger the app to update the data? Now, about four hours after the initial setup and a drive back home, there haven’t been any updates on the data.
Hey @Marcel_Vellekoop
Normally the sync runs every 5 minutes, I have to check myself it that works, as I haven’t moved my car yet :wink:
I’ll see later today how ti reacts with me.
Kind regards,
Hey @Marcel_Vellekoop ,
I’ve found a bug, and release v0.3.3 towards test, this should fix the sync process.
Kind regards,
It works…
Thx…
Here also.:grin:
It is working indeed! :love_you_gesture: Very nice!
May i do a suggestion for an extra flowcard: “When the car arrives home…”
For me it doesn’t do the trick. Tried reainstalling the car; no succes. Great job on the app nonetheless!
Ps. No SoC card available is that correct?
Hey @Daderu,
Could you share me a diagnostics report?
THanks,
Of course: 69aac7cb-df2e-4ceb-95d3-4315bd4d5b49
Hello Kenny,
This update is a big improvement. However, one variable isn’t getting a value “doel laadnivo”. I don’t have a charging pole. I charge my car with a charging cable with a smart plug. When “doel laadnivo” isn’t 100 I will charge the car when I return more than 2,5KW to the grid (solar panels and a P1). When I return less than the smart plug is OFF and when it’s more than It has to be ON. It’s must be also ON when “doel laadnivo” is 100 to override it because I will use the car. I think there is a little bug here. See screenshot.
Hey guys,
@Daderu - I see an error in your diagnostics report still, I’ll dig deeper into that and publish a fixed version during the next days.
@Pokemon - probably I don’t properly define that variable, I’ll check out.
Hi again!
I’ve been on vacation so I stayed on version 0.0.3 until getting home. Now the app is on version 0.3.x and another library.
@KennyMoens It seems that all triggers (when-cards) is removed in the new version. Will they be back or do I have to trigger every 2 minutes and read the metrics? For example I check if car is locked if it been stationary for 10 minutes and if window is open if car been locked for 10 minutes.
Nice implementation of Haversine formula (Car at home) :slight_smile:
My “need to charge calculator” has been useful on my vacation - I put distance to destination + 60 km into a variable and my flow calculates target charge (%) and resulting range (km) into a text variable. The calculation i based on present charge and range from Skoda app. Both variables on Homey mobile dashboard makes it easy to handle.
Hey guys,
@Daderu v0.3.4 is coming to test in a few minutes, this should fix your issue.
@Morgan which trigger cards are you missing? I still have them I think:
It seems like all the trigger cards are there. They are not published on the homey app download page.
Hey,
That’s because Homey auto-creates these card, appearantly their webstore does not recognise them.
Kind regards,
@KennyMoens
Doensn’t do the trick. Diagnostics report 41595003-d831-4388-a3ea-05b58e48317d
Ps. Now there is a slide button (which starts at 5000%), is that correct and what does it?
Please try again with v0.3.5, was another issue.
The slider is for the target SOC normally.
@KennyMoens
Damn, you is fast! And this does the trick!
Now got some data:
I will monitor after a drive etc. Might be that some will not be loaded based on type off subscription (some are a paid function in the Skoda app).
:flexed_biceps:t2:
The slider for max SoC goes from 5000% to 10000% . Would be nice because of range, but don’t think it works :sweat_smile:.
Again: great work!
I was trying to install the app, but then realized it seems not to be compatible with the Homey Pro (early 2019), is this going to be added in the future, or is this not going to be possible?
