Same here. During connection the correct data is retrieved and than no updates are received….
Hey guys,
For those where no data is syncing, could you submit me a diagnostics report?
Thanks!
Hello all,
A new version is available for test, I’ve added a few flow cards:
- A check if your car is at home (based on Homey’s location).
- The possibility to change the target charge level from a flow.
Additionally a number of translations have been added.
Thank you so much for developing this app and allowing us to connect our cars to Homey again!
Just a quick question: do you plan to add support for starting the climate from a flow or a button (that can be controlled by a flow)? It’s still quite chilly where I love, so it would be nice to map the climate to a physical smart button for easy heating of my car in the morning.
Hey @johbiraus
That’s next on my planning :).
For sure: d633678b-71ec-4c27-8430-bc92c06ec3ef
It seems there never is a connection in my site. Not seems any data here at any point.
Hello guys,
The diagnostics reports where we don’t get data don’t make me wiser at all.
I’ve released v0.2.1 towards test now, can you guys please try with this version? It should give me more output on what might be going wrong.
If it does not work yet (which I expect), please submit a diagnostics report when you notice it, and additionally restart the app wait 30 seconds and submit a new diagnostics report.
Thanks!
Good morning, is it possible to start and stop charging for my Enyaq?
This is with the new app, bedore restart app:
c30e52a9-a5fd-4429-9904-584bfcefde37
And this after restart:
02f51156-1ec9-4c34-97d3-24b074582f9a
Ook na restart nog geen data inderdaad.
Hey guys,
@Daderu the library gives errors as follows in your case:
2026-03-30 15:14:18,055 - myskoda.auth.authorization - INFO - Token expired. Refreshing IDK access token
2026-03-30 15:14:18,385 - myskoda.mqtt - DEBUG - Sending CONNECT (u1, p1, wr0, wq0, wf0, c1, k60) client_id=b'8f2fd97e-1ca9-4ee2-947a-4ab496dd96a0#7a4d7955-78df-495d-aa34-8a3c911ab840'
2026-03-30 15:14:18,410 - myskoda.mqtt - DEBUG - Received CONNACK (0, 5)
2026-03-30 15:14:18,411 - myskoda.mqtt - INFO - Connection lost ([code:135] Not authorized); reconnecting in 600s
I don’t have a direct clue what is causing this in your case. Based on a search on the issue tracker of the library I’m using, they typically as the question if you’ve answered all consent dialogs.
Could you try going to Škoda ID and see if you need to give some consent?
In you case, I see an error in the output:
2026-03-30 08:05:01,121 - skoda.app - ERROR - Caught global error: 'NoneType' object has no attribute 'in_motion'
This is a bug in the application, I’ll look into it.
Hey @Daderu
Yeah it won’t appear there. The Skoda app on Homey (and also Home Assistant) is not an official integration, therefore it does not appear in there.
Did you have to give consent when visiting the page? If so, please try to add your car again in Homey now, it can be that this is sufficient to get it working.
Kind regards,
Maybe way back, but when login in I do not have to consent to any thing (anymore) except for the darn cookies.
Tried re-adding the car, and tha gave me a bunch of new statistics/infometics. But still no info is retrieved. Want me to make a new report?
Hey @Daderu ,
Yes please, we are making progress.
Hey @PatK77
I seem to have the same problem with me right now. I’ll dig deeper into it to find out what is wrong.
