Done! Issue #3
Well, the way the LogFile works (how i call the module i wrote when i took over this app, because back then the limit for logs was 2000 log-entries) is also very must changed, for a huge improvement in less memory resources. This allowes for way more entries without the app being shutdown by the homey-sdk because of high memory used.
I the end of the test after finishing it yesterday, i got downloads even working with 100k logs, even exporting them to excelfiles and downloading them.
But i hope you will enjoy the widgets and SSL ![]()
Be sure to share nice widgets in case you make or adjust one ![]()
Hi Arie,
Many thanks for giving this great app much love.
Playing with the widget, I noticed a few things:
If Severity level is changed from the initially selected Notice to Debug, it keeps showing all severity levels when setting the Severity level back to Notice or more severe levels
In the “Compact” layout, the flow names are missing. In Olivier’s widget they show:
As mentioned by @SunBeech already;
at first it seemed the filtered results seem to be limited to the entries on page 1 (paging = enabled), but it’s the same without paging enabled:
Github:
Git issue # 4
Hey @Peter_Kawa ,
i have resolved all other issues in the comming update.
however, im unsure about this request. I didnt check all options in olivier’s widget actually, i hardly checked it at all tbh ![]()
Perhaps i should create one default Design and Theme to match his compact version?
But how will we call it then, because appereeantly, my idea of compact (way less info to reduce the sizes) is different from his.
@SunBeech and @Rrrr and @Drako74 (since you are all testers) do you guys also use(d) the Compact mode?
Should default compact included the App/Group name, or do we need to create another “compact”?
I can’t say I’ve ever used the Compact mode, and I doubt I would, I like the full fat all the details log myself.
Would it be viable to have a sub menu for which fields are included with tick boxes (like in the Filters menu for severity level)? Then users could pick and choose custom fields inclusion, without ending up with a million different themes/designs one for each person’s individual preference. Then the Design just controls the graphical elements and font type/size, and the theme the colour scheme. Otherwise you may end up getting swamped with requests for custom fields and designs, which I don’t think is fair, given how customisable it already is.
Well, not in a nice way: widget settings are pretty limited and except for an autocomplete (which only allowed one “answer”), you cannot create them dynamicly, just like device settings (this is why i mis-use repair views a lott like in AVD.
Well, to be honest, this is how i build my apps: extreem customisation options, with good defaults. So i dont really care to included more options.
Right now i created a default “classic” design which matches the other apps widget completely.
There is now a second timestamp element which can be separatly set, so the date in that design is a bit smaller then the time just like the other app.
I needed to run out though, and it might take some time before im back.
Yeah, this always happends: but thats what the templates are for. We’ll make the build in designs as good as possible, but after that, if users want a special design or theme, they can make it and post the templates.
There is an update coming later today which:
Changes the default level colors to match the other apps colors, they look good (and in theme this can be overwriten).
Also the template generater is english always and the images will be next to each other, so please wait with posting further templates till that version is released.
Thanks for testing and feedback y’all!
Maybe missing the “Flow name” was confusing, I always use the Group field for the flow name:
So, a better description would be, the Group field is solely missing from the Compact Design view (my fav view
I’ve checked each of the other Designs, they all do show the Group field ![]()
To compare, here’s the settings for Olivier’s widget, there’s no option to hide the “Group” field or anything:
Yeah, i installed his app and checcked everything, i see there are no other designs XD.
an update and new design is comming soon, just fixing small layout bugs between the designer and real dashboards etc
I don’t personally use the compact mode. For my liking the presentation is too dense. I prefer a little bit more spacing and clear headers (which is the app/group item).
But @Peter_Kawa uses the app/group field for longer texts: the flow names. I can imagine that in the standard layout, due to its length, those headers can become quite large (due to the larger font size).
Maybe an option would be to allow the user to change font size for each element and height of the blank space between the elements in widget designer (but I can imagine this might be an extensive change). Otherwise a ‘medium’ style that sits beween compact and standard would be an option.
Looks nice though ![]()
Just wait with posting templates till the next update, there are a few small changes (like the background color in the generated images etc).
The only thing I couldn’t figure out was how to change the colour of the day separator background/line and the background colour of the App/Group.
And I might change the filter icon colour back to something less purple ![]()
Select the Line element inside the dayseparator editor. ![]()
Simple (Sys) Log v4.0.2 is now available for testing!
Since the v4.0.0 announcement, I’ve continued improving the widgets and designer. This update includes the changes from v4.0.1 through v4.0.2.
More widget design options
The new Compact Classic design joins refreshed Default severity colors. You can format and style the date and time separately, and configure periodic updates, flexible height and additional filters.
Clearer designer previews and themes
Widget colors now better match Homey’s light and dark palettes. Select visible parts in Design or Theme mode to highlight them in the preview, and set log-entry background and border colors in Theme mode.
Syslog facility fixes
Facility names and filtering are now correct for all 24 Syslog facilities in widgets and Flows.
Widget Exchange previews
Template previews have been improved. Browse and share templates in The Widget Exchange(r).
Widget guide · Widget designer guide
Feedback, screenshots and shared designs are welcome below. Please report bugs on GitHub Issues, including your app and Homey software versions and steps to reproduce the problem.
Thanks for testing!
Figured it out now… endlessly distracted by playing with the design editor now ![]()
Just wait till you see my Universal Media Play widget ![]()
It is turning into a real UNIVERSAL media player, connecting to each device without configuring anything, im already starting to love it myself.
the widget editor will be huge though ![]()
