Worth every MB ![]()
Version 1.3 will be released soon (probably tomorrow, it’s awaiting approval by Homey) and will have support for podcasts. At the moment I can only create a trigger card to play the latest episode of a podcast series. The other options are not reliable yet. ![]()
Furthermore the memory usage has been improved, you will find some new trigger cards and some other tweaks ![]()
Fantastic thanks @Cyril_Hendriks I’m on the test version 1.3.3 so I’ll give the new cards a spin today. Also confirmed here the memory usage has indeed plummeted. Great work!
@Cyril_Hendriks Great app, thanks for making it! Very nice that I now have a possibility to start a playlist on my google nest audio thru homey! It would be nice if you also can add a song/artist/albums/playlist etc search widget like the spotify connect app has if that is possible.
That would be a nice feature indeed. I will add it to my to do list ![]()
I have created a similar widget. It’s in the test version at the moment and pending approval from Homey to be published on the main channel ![]()
Great! Like the rounded design of the buttons and search field. Works nicely that you can select your speakers from the popup but think that it also would be nice that you have the option in the widget settings to set is to a fixed speaker to make it dummy proof for situations where a dashboard is controlling a specific room and the “dummy” user
only has to start a track without knowing what speaker to start it to or accidentally changing an other room.
Yes, good suggestion! I’ll have a look at it in the coming days ![]()
I have just uploaded a new test version ![]()
This is great! Nice that you also have the option to choose what filters you like to see. Is it also possible that the all filter always is all and not all of the filters that are active in custom controls?
From a UX point of view, my feeling it’s better that an ‘all’ option reflects all available filters in the widget. What usecase are you trying to solve that ‘all’ represents all filters regardless of which filters are active? ![]()
I think your right, was just thinking that if I exclude some filters that the end user never can search for any of the other filters. I would like to make a selection of the most used in my taste like tracks/albums/playlists but if a end user want to search for a podcast or radio stream for example it is still possible by the all filter.
I understand your usecase and I will add it to a future version of the app. But currently I’m working on a new Homey app, so I cannot promise when I’ll have time to work on it. ![]()
I just saw that we reached the 200 installs of my app.
Thank you very much for that. In case you have ideas on how we can improve the app, please let me know!
I keep getting Music Assistant request failed: 401. I have installed the token, run the “Test connection” and 401 error message keeps coming. I have tested both ports 8095 and 8123 (that’s what the web ui shows of port),
Forget it was some nonsense with cut and paste and token.![]()
Have fun with the app!
Is it possible to change the font size and quality of the logo on for example, radio stations? On my Google Nest Hub, I would like to have room for a little more text, or for MA to adapt better to the screen.
Logo’s and fonts that appear on screens are handled by Media Assistant. There is not much that I can do in the Homey app for that unfortunately.
Hi @Cyril_Hendriks,
Would it be possible to add a ‘Then’ flow card that could clear the device queue? Unless it already exists and I’ve missed it!
Chers.
