[APP][Pro] Sensibo - Air Conditioning and Quality
Thanks, Dijker,
for the pointer to a clearly useful set of tips and hints.
However, the problem fixed itself when Homey issued SW update version 8.1.1 last night! So the 'do nothing approach’ to personal problem solving worked :wink:
…which brings into question the level of QA/QC with mutual compatibility checks when Sensibo installed SW update version 1.12.0, which clearly triggered this disconnect with Homey Pro?
Hi there,
Is it possible to add conditions for “Fan Mode: fan”?
As it is right now, it´s not possible to get the condition if heater is running in fan mode! :slight_smile:
/Robin
Hi, i considering buying a sensibo, but will the sensibo air pro also be added in the future?
Hi.
Has anyone been able to connect Sensibo Air lately? I’m just getting error “device not found” or “time out”…
Great app but I am missing something. I cannot set my Sensibo Sky to the “dry” mode only to automatic, heat, cool and off. In the Sensibo app on my phone I can set the mode to cool, heat, fan, dry and Automatic. Is it possible to add “dry” to the mode settings?
Where does the app get the last seen date and time info from?
I have a time difference of 2 hours with the actual time…
So is display the current time -2hours and when hovered the last seen is 3 seconds ago…
I did a search in the settings but i cannot find anything where i can change the timezone (i think it is using a wrong timezone)…
Got 2 Sensibo Air Pro’s and when trying to link to Homey, Sensibo says ‘No devices found’. Anything I missed apart from generating an API key?
Same problem here, I bought the Sensibo Air PRO 3-4-2023 but still can not pair it…
I have contact the support but they send me to the standard procedure… that won’t work.
I hope I can use the Air PRO soon…
If anyone has an solution, please let me know…
With kind regards, Mark
Don’t understand why questions regarding AirQ or Air Pro are consistently ignored here. Apparently there are a lot of people that can’t add their devices, myself included.
Have been trying to get this resolved for months now. No interest in helping us?
Hi @chrisroijens, @markjohan, @Sander_Retz
As you might know, this is a community-developed app. It is not developed, maintained or supported by Athom or Sensibo.
I have stopped maintaining the app, and am in search of a developer who is willing to handle both maintaining the app and handling all support requests.
Hi @balmli , may I know where we can find the latest source code for this? Thank you.
No updates on a new developer?
I am thinking of buying a Sensibo for my shitty Mitsubishi wifi thing but without an active app that seems not a good idea.
New Maintainer for Sensibo App
Hi everyone,
I am Tapio and will be taking over from @balmli the development and support of this app. First thing to do is to do the “paperwork” and republish the app with correct information, but nothing new yet.
I will be receiving my Air Pro this week so bare with me while I get to know the source and the Sensibo API.
Some of you may know me from other apps such as:
Thank you @balmli for creating the app and trusting me with it into the future.
Thank you for stepping up, and happy coding :blush:
Great to see that support for PRO is planned. Any idea when it will be ready?
New update (Live: 1.15.1)
Changes include
  • ADD: Support for Air PRO and the additional air quality sensors
  • FIX: Check for undefined values on capability updates.
Would it be possible to get a “when” trigger for filter needs cleaning?
Will need to check if the information is available from the API.
New update (Test: 1.16.5)
Changes include
  • ADD: Sensibo and SensiboPure - Add sensor for “Clean Filter” and trigger card.
  • ADD: Sensibo and SensiboPure - Add sensor for “Filter clean due date”.
  • ADD: Sensibo and SensiboPure - Add sensor for “Filter clean due hours”.
  • ADD: Sensibo and SensiboPure - Add sensor for “Filter run hours”.
  • FIX: All devices - Improved API error handling.
  • FIX: All devices - Add error handling to triggers (catch Promise rejections).
To test this version, please install from above version link.
If you do not want to test this version anymore, you can return to the live version by installing it from the app store.
@Exerqtor , you could test this one.
I noticed that Sensibo has a fixed filter cleaning interval of 12.5 days. Couldn’t see anywhere in the mobile app if that can be adjusted.
