[APP][Pro] Sensibo - Air Conditioning and Quality
Great request.
Setting climate react triggers would be amazing: temperature, humidity, feels like.
Another request is related to using my Sensibo Sky’s with external vthermo’s. Vthermo’s are great to average the temperature sensors in the room. I would like to be able to use the current average temperature and set that in the Sky as the real temperature if there is such trigger.
@balmi
Would it be possible to have a Trigger for Motion Detected by the Sensibo Room Sensor?
Or do they not have it in their API yet?
BR Magnus
Really like this app. Works always really great and I can do almost anything I want with my airco.
The only thing I’m missing is the fan only mode. I’m now doing it manual in the sensibo app or let home assistant take care of it when I don’t want to use the airco.
Is there a way to implement this in the app?
Hi
This app is really nice.
But my old Mitsubishi Kirigamine inverters beeps every time a command is sent/received, and that is kind of annoying.
I really miss a a flowcard to check current temperature setting if there is really a need to set the temperature again. (would save a beep every hour :wink: )
Example:
WHEN"price changes" to normal, AND temperature is/is not set to XX, THEN set temperature to XX.
Possible?
Best regards and thanks for a good app.
Sorry for my late response…
From reading the documentation here Set Climate React configuration, I would guess one can leave out the Low and High TemperaturState-values.
So some examples would be:
For daytime:
“enabled”: true,
“lowTemperatureThreshold”: 21.5,
“highTemperatureThreshold”: 23
For nighttime:
“enabled”: true,
“lowTemperatureThreshold”: 18,
“highTemperatureThreshold”: 20
Would this be possible to implement?
Hi @balmli
I try to connect the AirQ with the API key, but the list is saying no devices found.
Please help!
Thanks in advance.
BR. Fred
Hi @Fred_Woeltjes
Hopefully I will get hold of Sensibo devices and an API myself, so I will be able to test… And then AirQ should also be supported
I’m in the same boat. Compete cloud fan. Just received my bridge but missing sensibo…
Still no plans?
I’ll have to return the bridge if so…
Thanks.
Br,
Gabor
Is the homey in contact directly to the sensibo? Or does it send its control signal vua the internet ?
To rephrase, is the api ob the device or is it a cloud service on the internet.
The question i am interested in is of course if the steering can work when internet is down?
There are multiple people, myself included, who are having issues adding the Air devices… Is there a way to add them or is it time to look for other devices. The Sensibo Air devices are quite useless if I can’t integrate them with Homey.
Add Device > Fill in API > Device not found. Tried 100 times now. Whenever I google on Sensibo Air homey support the page takes me to this Homey App
Does this mean that the Sensibo device should work as a thermostat? I’m trying to use VThermo to control my Sensibo Sky, but it only seems to be able to use the measured temperature from Sensibo, not set the target temperature on the Sensibo.
Edit: Nope, never mind, works fine. I forgot to account for the actual temperature when expecting the target temperature to change.
Yep, it’s a cloud service.
How do you tell the app too use the room sensor and not internal sensor?
Seems like after Sensibo installed SW update version 1.12.0 the Homey Pro smart hub app ceased to pick up temperature & humidity readings, as well as the ‘Desired temperature’ parameter!
The Sensib Sky is OK, as it continues to interface perfectly with my Tibber Pulse through the Tibber Power-Up for Sensibo Sky
Any help, anybody?
I need help adding Sensibo Air in Homey. Sensibo Sky works excellently, but Sensibo Air won’t show up. Any ideas?
I have a Haier Tundra 5 kw airconditioner (type AS50TDDHRA-CL) with the wifi module.
Now I want my Homey to communicate with it because it’s only connected with Google Home Assistant at the moment.
What device do you suggest to do so? I’ve searched the internet for the differences between the Sensibo Sky and the Sensibo Air but I can’t see what great differences the Air makes from the Sky with my needs. Any suggestions?
When you are connected with google home you have the ability to control it with Homey. Connect Homey with google assistant. Make a virtual device and it will synchronise with google. In google you can make Routines what has to happen if the status of the virtual device changes.
Thanks for your reply Marcel.
The problem with Google Home is that the connection between Haier Uhome and GH disconnects on a daily basis. “I cannot sync with Haier Uhome”, states Google…
So I think that it’s better to use Sensibo or Tado :slight_smile:
Aha i that case, i have the Sensibo sky. Works perfect. I looked up the differences between sky and air
Thanks! We’ve purchased the Sensibo Air + Room Sensor. I look forward to play with it :nerd_face:
