@Luca_Lorenzi yes I can add that
And if 2 are planned for the same time 2 will fire
Great, as always! I’ll buy you a coffee <3
Changelog:
NEW:
1: NEW: update settings page
2: NEW: add dashboard widget
3: NEW: add “recurring message” card
4: NEW: add “delete a recurring message” cardFIXES:
1:FIX: None
More - apps - Schedule Message - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - Apple Findmy - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Via Homey Webapp:
Settings wheel bottom left - Select Apple Findmy - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
Don’t want to be part of a test version? Install the live version → Schedule Message | Homey
Widget:
Settings Page:
@Luca_Lorenzi see the test version above, please give it a spin when you have time ![]()
@Luca_Lorenzi when you did run it, can you confirm if everything works as expected? Then i’ll push this version trough to live ![]()
@martijnpoppen everything works as expected! Here a screenshot of whatsapp with the queue of scheduled messages sent:
@Luca_Lorenzi great! Glad it works. Hopefully the improved settings page helps as well!
Changelog:
NEW:
1:FIX: None
Via Homey Webapp:
Widget:
Settings Page:
